hi anyone familiar whit ENgenius? i cannot see ezb-4
— Edited
5 Participants
The Navigator
— Path-planning navigator using ARC NMS position and obstacle data to map, log trajectories, and autonomously follow waypoints.
If I get some time today, I will try to connect to the ez-b with my android and get more familiar with it. I need to do this soon anyway. I will let you know if I see anything that needs to be mentioned.
I have to prepare to teach today along with my normal job. I dont think I will have time until this evening.
Thanks David
d cohran thats ok.i saw on the webpage ap mode is the ezbv4 from android.
i found it all back thanks to alan&d.cohran&rr it was resetbutton and ip android is diff then ip pc.
thank you all
simpel app whit two servo and voice.
If you used the reset button on the ez-B, you are now back in AP mode, which allows devices to attach directly to the EZ-B without being on the network. To get your computer to access the EZ-B again, you will have to switch it back to client mode.
Just wanted to let you know incase you run into issues when you use your computer to try to connect to the ez-b.
d.cohran sofar all good.its diff proces avery time to use your android but am very happy whit achiefment.
@nomad... AP mode (as d'cochran said) is for any device connecting directly to the ezb, not just your android... Client mode is where your ezb becomes part of your wifi network and devices like your PC connect to it indirectly through your router...
rr
yes i saw the video link you gave.
