hi anyone familiar whit ENgenius? i cannot see ezb-4
— Edited
5 Participants
Variable Watch
— Live view of script variables, types, sizes and values for debugging; auto-refresh, hex view, pause/clear; may affect program performance.
@nomad... See here Wifi Modes
rr i saw this video.alll is ok on that page.
thanks
It's not the video, read what's below.... Tells you the difference between WP and Client modes...
Patrick,
Are your other wifi devices able to see each other?
I think I have the router set to restart nightly so a restart of the router shouldn't be needed. Your SSID is EnGenius. Do you remember your password? if not I will send it to you.
You will need to use a phone to connect to https://192.168.1.1 after connecting to the EZ-B via your wifi settings. At that point you will need to go to client mode and then put in EnGenius for the SSID and enter your password. You will then tell it to apply the setting and click okay on the box that pops up telling you that you are going to loose you connection to your network.
At that point, the EZ-B should reboot and tell you that you are on your network. We used mac filtering so if this is a new EZ-B, it wont be allowed to get onto the network. if it is one of your other two EZ-B's they will work.
At this point, you will have to scan for the EZ-B in ARC so that it knows which IP was assigned to the EZ-B by the router.
Please try this and let me know.
Thanks David
hi d cohran
i made this android app.thats when i spotted the error. i wanted to test it.
i know my password.its not a new ezb4 i let you know,thanks
Is the android app setup to connect to the network? I think we left it to be able to connect to the wifi.
It looks like you are able to connect from your computer to the EZ-B without an issue. Is this correct?
yes i can connect on pc on android it says engenius
What color is the light on the top of the ez-b and is it flashing or solid?
