ADC Value icon ADC Value — Display ADC port voltage and 0-255 linear values (0-3.3/5V); configurable board/port, units, multiplier and sample interval. Try it →
solid green for pc
#26
On your pc, which wifi connection does it say you are connected to?
yes am succsesfully connected
#28
The Android apps will default to 192.168.1.1:23
After opening the your app in ARC Mobile, when you hit the Connect button, you need to update the IP address to the address of your EZ-B. The Android app does not have a search function so you need to know the address.
Also, ARC on your PC can not be connected when you try to connect with Android. It is one or the other, not both.
I am going to ask you a list of questions. Please answer each one of them.
Does the app work from the PC?
In your wireless connections on you PC, what does it show as the network that you are connected to?
What network does it show on your android?
What I am assuming is the following
The PC is connecting to the EZ-B in AP mode which bypasses the Engenius router. The PC is working with the app.
The Android is connecting to the engenius (in client mode) Because the EZ-B isnt in Client mode and not on the engenius, you wont see it from the Android.
Please answer all 3 of the questions above.
Thanks David
d,cohran yes the app works on pc engenius engenius
thanks alan
that was one off mine question to
#31
This is all good news. So the issue isn't with the network. I haven't tried the android app much at all. Alan sounds like he has. Please follow his instructions for changing the IP address to access the EZ-B.
If you are connected to the EZ-B on the PC, write down the IP address that it is using to connect to the EZ-B and then disconnect. From there you will need to put this IP in on your android as Alan discussed above to connect to the EZ-B.
d,cohran
ok thank you very much. indeed ip is the one alan says.
