robotmaker
— Edited
9 Participants
Camera NMS Pose
— Overhead camera tracks a glyph to give precise robot pose to ARC's NMS for multi-camera indoor/outdoor navigation and waypoint control
DJ i check config in camera ,only can save one photo,so how do you save a lot more,same with object detection too,there is more then one object in a house,and i would think on faces ,more then one.
Second how does it compare them,dont see anything in camera controls or config
Tracking, Custom turns on tracking for the custom detection.
You can only load 1 Haar XML at a time.
yes i know,so it really doesnt compare with a few faces only one,so its only tracking not recognizing faces or objects
Tracking is good for if you want to track a person moving around or one object like a ball
Where recognizing it if many people in the room comes up to the robot it will compare with the same face in the data base,and auto add the face if you write extra softare for it.
Same with objects too.would really good to have this feature in EZB.
@RobotMaker, you would need to use the EZ-SDK to become that customizable. If I were to add multiple Haar Cascde detection in ARC, you would need a very powerful computer. Roborealm has some neat features. ARC has more.
BUT not many in video processing ,and you have to be a very good programmer to use the SDK
To me it looks like french
I was able to use 9 faces and i can add many more in HAAR cascode detection using only windows xp pro and single 1.6 ghz without the resouces or speed get used much in windows task manager
Hope Steven from roborealm will make a interface soon so EZB CAN have access to over 100 filters and modules for VIDEO PROCESSING
DJ how many video or camera filters and modules does EZB have ?
@DJ, I have a Vflash and a new Projet 1500 cranking out my android head parts. Mine will have a silicone face that slips over the under skull. I should have the prototype and molds done by February and will be selling them on my website soon. Perhaps I'll scan and pull a mold off of your animatronic head and create custom faces for folks to buy and place on your heads?. Anyone interested? If so what type of faces would you like to see?
Did you find someone to fill your Solidworks position? Many seats here in LA.
also about harr cascode correct if i am wrong DJ, i thought its only for saving or tracking a image so you are only using it once.
IN comparing faces for recognition,you save many faces in a folder and then compare one image to it till its found.
this may be a bit offtopic right now, but it's related to the very first posts of this thread:
i wonder if you've seen this video, @robotmaker :
this face can express many emotions for sure.@DJ , is this possible with the EZ-B kit? (perhaps 2 boards, since it needs 23 servos excluding other things) i'll defenitely buy it if it's available here.
and when exactly will the robot face be available (the one in the first posts)? (so i can order it together with my ez-robot set)
