Rplidar icon Rplidar — Slamtec Lidar driver for ARC; scans 360° and publishes distance data to NMS for mapping, obstacle avoidance, and navigation. Try it →
DJ he be able to walk down the street and look and act human like the said in the video clip
Showing emotions in a head is the easy part
It little off topic DJ ,but can EZB recognize faces from one face to another and tell its name. also like in a crowd be able to pick the person out and say (HI DJ) Thinking it needs a photo data base to find a match,same with objects too,and objects may need more then one photo data base for each room
That would be along the lines of https://alereimondo.no-ip.org/OpenCV/ to detect custom objects like clocks, pens and I assume faces would fall in to that too... Face may be a bit easier thinking about Android's face unlock security feature...
There is a topic about custom detection somewhere on here.
@RichMR2 ARC also supports the exact same features as OpenCV for detecting objects. However, like OpenCV, you need to create a Haar Cascade of the image with a classifier. It's not an easy task.
Press Config on the Camera Control to access the Custom Detection configuraton.
Robotmaker and Rich...DJ has solved the face recognition issue by having EZ-B recognize QR Codes! ...slap a QR code on the forehead with the persons name! In a robotic voice..." stop frowning DJ , I was barely able to read your name":) (tongue in cheek)
hahahaha qrcode face masks
#15
Thanks DJ for creating the head frame! I have already started on FRED but looks like he'll be getting a little brother:)
#16
I guess i need to test it and compare to OPENCV I do like ROBOREALM alot better and hope it makes a interface to EZB soon it has so many many modules for face and object detection ,color changes,math, it will be a long list to add ,since its a video processing software and very good add to EZB plus makes DJ job a lot easy too
here is a link to all the modules and filters well over 100 for video and i think more then 50 on robots and boards,one looks is it detects skin color.
roborealm list of modules and filters
