Hey guys,
Sorry for all the questions but I recently got a wave of ideas and I need to fine out if they would work with using the EZ- B Controller. Anyway,
Can anyone recommend a wireless joystick controller like the wireless xbox controller or the PS3 controller or any other wireless joystick controller that works really the best with the EZ- B Controller?
I really like to use the left stick to either X or Y axis and the right to control also either the X or Y axis also I would like all the buttons to work in junction with a MP3 trigger. for example : I can assign all the buttons to a specific mp3 sample and assign the D-pad to toggle through all the mp3 files that are stored on the card. And maybe make one button like a random button, by pressing it, it randomly selects a file and plays it.
Any recommendations on a controller that would work these task that I'm asking? Or is this something ez-b does already and I haven't played around enough to find it.
Thanks
Hello Hoolagen1,
One way to tell if your joystick is working with ARC is to open up the joystick control, select your joystick from the drop down if it isn't already selected, click on the config button, then press on some of the buttons, if the different button selections are lighting up blue whenever you press a button you are golden. If that doesn't work, maybe try another driver for your joystick until you can get the buttons to become active.
Once you have that working write in a command like ServoDown(d18, 2) in the Btn Down Cmd category and then something like Servo(d18,16) to return the servo to a certain position once you've released the button that you have written these commands for.
