Bot Libre icon Bot Libre — AIML2 chatbot client for ARC connecting robots to Bot Libre cloud for customizable, private chatbots and personalities. Try it →
Animatronic Head - Mouth Moving Faster Than Audio
Hi! I'm rather new to ARC, but a friend and I are trying to put together an animatronic head (from Robotics Squared) that will answer questions and look around, blink, move its mouth, etc.
Right now we're using a slightly modified script that @Rich posted to take the variable from the Sound servo control and open the mouth to different levels.
The sound coming into the Sound servo control is being supplied by SayEZB commands in the Speech Recognition control, so that we can have it answer questions and phrases.
Our problem is that the information going to the Sound servo variable is going a lot faster than the actual speech coming out of the speakers. We're thinking we can fix this by piping raw audio out of one port and into another, reading the levels there as the robot is talking and have the actual audio move the mouth.
Our problem with that solution is that we don't know how to pipe the audio out one of the ports. It doesn't even have to be true audio, just approximate volume levels that are fairly true to the actual speech. Anyone know how to pipe synthesized speech out of one of the connectors?
Any help would be greatly appreciated!
Andrew
(P.S. I'll try to check this every evening, but we're only meeting once a week to work on the project.)
Absolutely. This is my favorite part of all things EZB. JD's commitment to the products, being personally involved in his company on a level that's just unheard of.
Hi again!:) Is there any way that I could get the ADC ports to read input faster than 100ms? I've set up an envelope follower circuit so I'm able to get the mouth to move with the audio, and I set up a software audio delay program on my PC to sync the sound to the mouth (Audio Delay by Fountainware), but the ADC port seems to be missing most of the signal - it's updating the android mouth maybe twice a second, all told, which gives it a really jerky and unpredictable appearance. I'm thinking that if there is a way to read the ADC port and write that to the servo more fluidly, this would help the project along a lot.
One other option we're considering is inverting the envelope follower, DC offsetting the inverted signal to make the android mouth set in the right range, and having the whole mouth-motion go through an analog circuit instead of through the ARC, and then saving the EZB for doing things like turning the head, blinking, etc.
So anyway - anyone know of a way to increase the read/write speeds of the ADC and digital ports?
Thanks!
I am working with another EZrobot member now to work on servo sync to speech , we are using a different method of solution that does not require adc. We are very early into this and will post our results when we have it worked out to the point we are ready to show it. basically it reads the text string and parses it for phonetics and creates the timing for the mouth then plays the speech synced to the mouth moment. early tests have been promising.
Awesome! I'd definitely be interested to hear what you do in your project and how it turns out. We're going a little bit different path, where we're hoping to be able to feed any audio at all into the input and have the android lipsync to the audio. It seems that the ez-robot's bus may be a little too slow for that translation, leaving our android's mouth output jumpy. We're also chasing down another option for the servo controller, based on a project here.
Still hoping there's some way to speed things up on the ADC-in, so that it can sample a bit faster than what we've seen so far.
Hi, so I'm a super noob to the EZR world. But... I saw this thread & thought maybe you could help. In my heart of hearts I'd like to have an animatronic head that will have somewhat phoenome-type mouth movements that will happen in real time to audio input... in oter words; I wanna speak into a mic & have the animatronic head move it's mouth in sync with my voice. Thoughts?... is this even possible through the EZB? Thanks all.
With a few sentences, yes, it is possible. If you want to do a lot of text, I would look at the scary terry board for controlling the mouth and the ez-b for everything else. The Scary terry board is more of a low level controller designed specifically for this purpose.
#16
Updating this control for faster response for audio is actually on my list and is approaching quickly. Maybe a release or two away
