Python Native icon Python Native — Run real CPython in ARC with full package support, camera access, ARC APIs, and bidirectional robot control. Try it →
Animatronic Head - Mouth Moving Faster Than Audio
Hi! I'm rather new to ARC, but a friend and I are trying to put together an animatronic head (from Robotics Squared) that will answer questions and look around, blink, move its mouth, etc.
Right now we're using a slightly modified script that @Rich posted to take the variable from the Sound servo control and open the mouth to different levels.
The sound coming into the Sound servo control is being supplied by SayEZB commands in the Speech Recognition control, so that we can have it answer questions and phrases.
Our problem is that the information going to the Sound servo variable is going a lot faster than the actual speech coming out of the speakers. We're thinking we can fix this by piping raw audio out of one port and into another, reading the levels there as the robot is talking and have the actual audio move the mouth.
Our problem with that solution is that we don't know how to pipe the audio out one of the ports. It doesn't even have to be true audio, just approximate volume levels that are fairly true to the actual speech. Anyone know how to pipe synthesized speech out of one of the connectors?
Any help would be greatly appreciated!
Andrew
(P.S. I'll try to check this every evening, but we're only meeting once a week to work on the project.)
#17
d.cochran, thanks much, I'll check out the info & the scarry terry!
DJ Sures, Very cool! And can I just add to the schmabbillions of other people saying "tank you!" for this kit... I got a Dev kit about a month ago & just now have some spare time here and there to play w/it. Very excited!
#18
Thank you for the kind words:D Looking forward to seeing your robot!
#19
An alternative to the scary Terry board (I hadn't heard of that one, I'll have to check it out) is the Auto Talk board available here
#20
Scary Terry board
I like this one because its $59.00 and It uses pots to adjust min/max servo movement and sensitivity. It can be tuned to work well with your application. It can also drive LED's and other devices along with the servo.
There are mic and audio in jacks. It allows you to just process the left or right audio channel or both. Its a pretty cool board.
