hi
i would like to make a base with a on/off switsh like in pic,would this work ?
PWM Servo Feedback (I2c)
— Real-time servo position input via Arduino ADC over I2C; supports Nano (6 channels) or Mega (16), configurable I2C address and scalable chaining.
Yes, but I would put the switch first and then the fuse.
So to keep the fuse you'd desolder the holder for fuse then run wires from the fuse holder. Unless you want to solder the fuse inplace.
just to be sure i can solder direct on the fuse pads,see pic cirkel.
ok here it is ,the base with on/off switsh. also it would be nice to have a batt case.
That yellow fuse is rated at 20 amps. Highly doubt those switch contacts are. Nomad be careful
The fuse original is 20 amps yellow.
its same switsh as jd body.?
are these desame on/off switshes as used by ez robot ?
on/off switsh
