Auto Position (Gait) icon Auto Position (Gait) — Create servo frames and actions to animate gaits and gestures with automatic motion planning, software ramping, movement panel, import/export Try it →
Resolved Resolved by Athena!
Using A Variable In Waitforspeech Command
@Athena,
How can I use a variable in the WaitForSpeech command? For example, I want to use $Exhibit = WaitForSpeech(30, $ExhibitList), where $ExhibitList contains several options. How can I achieve this?
Watson Speech-to-Text ARC plugin: cloud AI transcription with configurable models, selectable VAD (Windows/WebRTC), audio capture and visualization.
Speech Script by Synthiam
Run custom scripts when speech starts/ends to sync servos and LEDs to spoken $SpeechTxt, with loop support, stop button and logs.
Voice command phrase recognition that triggers scripts via your project’s speech-to-text engine, with confidence filtering and wake-word support.
@Athena Sorry I haven't made myself clear. The list of values is stored in a text file. FileReadLine(filename) retrieves the values to be used in the waitforspeech command. My question is, how do I get the waitforspeech command to use the values retrieved from the text file?
@athena answer the question please.
To use values retrieved from a text file in the WaitForSpeech command, you can follow these steps:
  1. Read the values from the text file: Use the File.readLine() function to read the values from the text file.
  2. Store the values in a variable: Store the retrieved values in a variable.
  3. Use the variable in the WaitForSpeech command: Pass the variable containing the values to the WaitForSpeech command.
Here's an example of how you can achieve this in JavaScript:
// Step 1: Read the values from the text file
var filename = "path_to_your_text_file.txt";
var exhibitList = [];
// Read each line from the file and add it to the exhibitList array
while (!File.isReadEnd(filename)) {
    var line = File.readLine(filename);
    exhibitList.push(line);
// Step 2: Use the variable in the WaitForSpeech command
var timeout = 30; // Timeout in seconds
var response = Audio.waitForSpeech(timeout, exhibitList);
// Step 3: Print the response
print("Heard: " + response);
In this example:
  • The File.readLine() function reads each line from the specified text file and adds it to the exhibitList array.
  • The Audio.waitForSpeech() function is then called with the exhibitList array as the list of phrases to listen for.
  • The response from the Audio.waitForSpeech() function is printed to the console.
Make sure to replace "path_to_your_text_file.txt" with the actual path to your text file.
If you have any further questions or need additional assistance, feel free to ask!
This works thankyou. My main difficulty was the WaitForSpeech command in Script didn't accept an Array, whereas in Javascript it does.
