Inverse Kinematic Arm icon Inverse Kinematic Arm — Control robot arms with inverse and forward kinematics, converting X/Y/Z positions into joint motion and reporting end-effector location. Try it →
rr
you saw me just doing that in the video.
david i ad the new ezb on Engius.ubove is a check box something for mac. chould i check that box or uncheck.
#18
I have to head into a meeting and then after work I have to go be my wife's companies lift monkey because they just bought a bunch of furniture. I will connect tomorrow if you cant find the notes that you had from the last time we did this. Let me know if you get it figured out. If not, I will connect and get it going for you. You might want to find your password for your router configuration while I am away.
#19
If you can get into your router with the login information for your router, you could uncheck MAC Filtering. We could try that and see if your neighbors have quit trying to hack your network over the past year.
david
no hurry got time,this ezb is for the ez mip.no inverted pendulum yet. i check what you say uncheck mac.
thank you bolt
checkbox unchecked
new ezb
@Nomad... Your video was fuzzy so I could tell what you typed....
i know how it works ,am just gggrrrr i cant find it and had to ask again. the other side is that i can practise again.maybe the problem is we dont know the ezbv4 number
#24
Okay, if you disable MAC Filtering like in your first photo, you should be able to click apply button. From there, you would just run through the connection stuff again for your EZ-B.
