Camera Click Servo icon Camera Click Servo — Interactive camera control for ARC: click-to-center and edge hotspots to pan/tilt servos, adjustable fine-tune and multi-camera support. Try it →
Stl Needed
hi all
is there anyone that can make me an stl file,the cost here in belgium to make an stl,is very high+cost material and chipping.also you dont get the stl file, companies says its there property.you dont have to do it for free ,but i , dont want to spend to much on it.
what do i want is a hip case ,similar like the neck part jd,but for 2 big servo's. the ones we use here ,lever servo's.color case is white.i want to give jd , some freedom more ,to be able take side steps.
the servo's comes together with no end piece where normal a screw sits. on top servo,here are some pics.
thank you
#34
@DigiEddy The hips require a specific project, not the standard JD project. For reference, this is mentioned in the instruction video, this thread, and the description of the 3d printable part for anyone else reading this.
*Note: at the time of this writing, the jd with hips project is not complete. It does not have optimized walking and movements to use the hips. We're slowly working on it, and feel free to contribute:)
You can get additional apps using either EZ-Cloud from ARC or the Robot AppStore on this website: https://synthiam.com/Community/EZCloud/RobotApps.aspx
dj
thanks for mention this.am gonna try the side steps ones i got my 3d parts.
howmany downloaded the stl from the hips ?
i got the hip part,but the size is not correct.you can pull the backside easly off. eather the bottom inside must lift 2 a 3 mm or the nots on the backside, 2 a3 mm longer so the bracket cant come off.
here are some video's.
here you see where the 2 mm is missing,it also prevent the bracket from, getting stuck on the head from the screw.
