Lidar-Lite Laser Module icon Lidar-Lite Laser Module — Laser Lidar-Lite ARC control reads distance, velocity and signal strength (0-40m+) via EZ-B v4 i2c, setting EZ-Script vars for robotics Try it →
Speech Recognition Questions
i must say i am a newbie in this robot thing but i ordered my complete kit and i want to use voice control..but iss not picking my voice up and i dont know whether is because of my accent (Ghana accent) or i havent done the right configuration..i looked into the video tutorials yet i cant set it up...please someone should help me
#25
wow..i got the same thing Loaded speech recognition with en-GB culture Set Dictionary Error loading phrases (Custom): The language for the grammar does not match the language of the speech recognizer. Set Dictionary Error loading phrases (Custom): The language for the grammar does not match the language of the speech recognizer.
#26
@RichMR2 whiles we await for the solution to the speech recognition,would like to u help me with the other servo configurations for the omnibox...i am tryin to use that as my first project but i am totally lost since i am a newbie..i have seen the tutorials several times but looks very difficult to configure the arms,the head,and the legs of the omnibox...do u mind me adding u to skype so that u cld give me a step by step tutorials
#27
Solved!
OK, it seems ARC doesn't like the UK profile (or anything but US I am assuming) for VR (perhaps something for a future update if DJ has time, although the following fixes it... in a way)
Click start Click control panel View by Large Icons Double click Speech Recognition Click Advanced Speech Options Change the language to US.
Click OK Accept the popup stating it will be changed next time Speech Recognition is started.
It should now work in ARC (please let me know either way)
#28
BINGO! YOU ARE THE MEN!....Thanks alot man...you guys are just tooo awesome...now let me see if my speech recognition would work...would get back in a few minutes
#29
ook so my only problem now is to get my speech recognition working...do you think it can be because of my accent? if soo,how do i get to train it with my voice?
#30
Go back to speech properties (as in my last message) and click on the "train profile" button. All recognition training is done in windows not ARC.
#31
ook...i am now done with the training in windows...so please,what do i do next?
#32
ARC Speech Recognition tutorial is at https://synthiam.com/Tutorials/Help.aspx?id=90
When you first add speech recognition it auto populates with a few commands, add your own and the script(s) for the command then just say the command.
You will need to have the robot's servos and Movement Panel set up before anything will work, speech recognition can only control what you have told ARC is there.
Check it works by adding speech recognition and say "robot move forward" and it should move forward provided you have set up the movement panel.
Follow the tutorials and it all becomes clear, the best way is to build the EZ-BoxBot which DJ has provided many video tutorials for which will guide you through the whole process from unpacking the EZ-Robot Complete Kit.
