UBTECH Alpha Servos UBT-12HC icon UBTECH Alpha Servos UBT-12HC — Control UBTECH Alpha UBT-12HC smart servos via ARC using EZ-B v4/IoTiny UART, assign virtual ports, set baud, custom bits and position mapping. Try it →
Turkey
Rover 2.0 Connect Question
Hello...
I use ARC but couldnt connect rover 2.0. show this report,
13.06.2014 22:39 - Rover Error: System.IO.IOException: Aktarma baglantisindan veriler okunamadi: Baglanilan uygun olarak belli bir süre içinde yanit vermediginden veya kurulan baglanti baglanilan ana bilgisayar yanit vermediginden bir baglanti kurulamadi. ---> System.Net.Sockets.SocketException: Baglanilan uygun olarak belli bir süre içinde yanit vermediginden veya kurulan baglanti baglanilan ana bilgisayar yanit vermediginden bir baglanti kurulamadi konum: System.Net.Sockets.Socket.Receive(Byte[] buffer, Int32 offset, Int32 size, SocketFlags socketFlags) konum: System.Net.Sockets.NetworkStream.Read(Byte[] buffer, Int32 offset, Int32 size) --- Iç özel durum yigini izlemesinin sonu --- konum: System.Net.Sockets.NetworkStream.Read(Byte[] buffer, Int32 offset, Int32 size) konum: System.IO.Stream.ReadByte() konum: EZ_B.BrookstoneRover.Connect()
you can help me ?
thanks...
Hi, I am not sure what to do with this address, it always comes up as
"This page can’t be displayed" how do I connect?
Regards Peter
#34
Dear Loupy31,
You need to connect WiFi to your Rover V2 before connecting the address.
Thanks for that, OK, I have the page up, it is asking for a user name and password, Can you help with that please
Regards Peter
#36
I typed AC13/AC13 in my case.
#37
The issue i'm having is with the video decoding. I have found a project with example code but it's incomplete. i'll be working on it more next week:)
#38
Dear DJ Sures,
I really appreciate your support!
FYI, I have found some library files from Rover V2 Android Apk file. It seems to be related to audio and video encoding/decoding.
I am not sure if it helps you or not, but I hope that helps you indeed.armeabi.zip
#39
Hi @DJ Sures,
Maybe you've already stumbled upon it, but I found a Python implementation that you might find interesting as well to sort your video issues out: home.wlu.edu/~levys/software/roverpylot/
Hope this helps,
Please keep us posted!
#40
Hi DJ Sures,
Do you have any update on this project?
Thanks!
