Debug icon Debug — Central ARC debug window routing logs; shows UTC date/time, Windows/ARC/skill/hardware info, version/settings, with copy and clear. Try it →
Turkey
Rover 2.0 Connect Question
Hello...
I use ARC but couldnt connect rover 2.0. show this report,
13.06.2014 22:39 - Rover Error: System.IO.IOException: Aktarma baglantisindan veriler okunamadi: Baglanilan uygun olarak belli bir süre içinde yanit vermediginden veya kurulan baglanti baglanilan ana bilgisayar yanit vermediginden bir baglanti kurulamadi. ---> System.Net.Sockets.SocketException: Baglanilan uygun olarak belli bir süre içinde yanit vermediginden veya kurulan baglanti baglanilan ana bilgisayar yanit vermediginden bir baglanti kurulamadi konum: System.Net.Sockets.Socket.Receive(Byte[] buffer, Int32 offset, Int32 size, SocketFlags socketFlags) konum: System.Net.Sockets.NetworkStream.Read(Byte[] buffer, Int32 offset, Int32 size) --- Iç özel durum yigini izlemesinin sonu --- konum: System.Net.Sockets.NetworkStream.Read(Byte[] buffer, Int32 offset, Int32 size) konum: System.IO.Stream.ReadByte() konum: EZ_B.BrookstoneRover.Connect()
you can help me ?
thanks...
#25
DJ Sures,
I have not been very happy with the performance with the rover, I was wondering if I buy the EZ-B v4 WiFi Robot Controller, will that fit inside the case? Is that all i need or do I need a motor controller? will the current cam work with the EZ-B or should I order a cam?
The current setup looses the wi-fi all the time. I need it to work when I turn it on and not have to play 15 min to get it to work...
I like what you have so and the look of the rover, so if I can combine the two, I think it will work for me...
Thanks
Christic
#26
Hi DJ,
I'm a new EZ-B v4 owner and new to your site. I purchased 2 Brookstone Rovers about 6 weeks ago during their sale thinking they would be usable with ARC. I have read the posts here and understand the differences and time required on your side. I will add my name to the list of folks who would love 2.0 support...and will enjoy your other items in the mean time.
Thanks,
John
Hi, I'm Peter from Australia, I also purchased the brookstone rover 2.0 last week, I would love to see some support for this.
Cheers
#28
I am yet another person who just bought a Rover 2.0 so add me to the list of people waiting with baited breath for support.
Thanks for all you do.
#29
The development of hacking the rover is still on going:)
#31
Cool! DJ Sures! Thank you for your contribution to Rover V2! I can't wait to see it working with your solution!
#32
DJ Sures, I have found something on Rover 2.0 and would like to let you know. You can connect a test page on Rover 2.0 using the following address: https://192.168.1.100/AC13.htm Hope that helps you:)
