HMD-16 rev:01 2007 does not show correct pinout for IR connector... gnd is there
Can you advise thanks!
Drone Collision
— Add HC-SR04 ultrasonic sensors with an EZ-B to AR Parrot Drone v1/v2 for collision detection and avoidance
Soz to explain I want to connect EZ to this robosapien.........
HELP?
I have never seen that board before. Sorry, I'm unable to help you.
Thanks DJ much appreciated.....it must be a later build....I will have to find an older one.. Cheers!
Wow wee has caused us a lot of headache with various revisions of their boards.
For sure! Took me forever to hunt down a compatible roboquad.
Just a short heads up must watch
thanks
https://vimeo.com/75776326#
https://raffaello.name/
Hi Guys, Maybe this is late but i just got a robosapian X and found that the IR out is the 3rd pin from the Left on the head connector. You will see a small solder pad connected to the bottom of that, that is where you can connect to. I hope this helps. If you look at the old boards they are similar but laid out just a bit different.
