Virtual Reality Robot icon Virtual Reality Robot — Stream robot camera to VR and control servos with headset pitch/yaw; supports SteamVR and Cardboard (iOS/Android) for immersive teleoperation Try it →
South Africa
#18
Thanks very much for all the input gents especially you bucknerbg27 I will attempt this over the weekend and advise I was NEVER going to attempt it NOT knowing the correct pinouts and damage my EZ Robot
be well!:D
something I found quite amazing: check out this website wow!
https://dronesurvivalguide.org/
#19
Slight correction, the Vrx is actually Vre (see image)now that i look at the other boards. Hope this does not inconvenience any one attempting to work on their robots. Happy Robo Hacking!
Thanks everybody. My board is more like Nomads so the IR Out is labeled well. I just need to have clarified, will I be connecting my data wire to IR-Out or some other pin. I know the ground goes to GRD but not sure what to connect the data wire to. In DJ's video it's just an IR and, it's never clarified weather its the in or out or send or receive just IR. Thanks for helping me out guys. I really do appreciate it.:)
#21
You have 3 wires or pins... grd, +V and data... IR out/in would connect to your data pin on the ezb...
#22
OK Thanks. In the video JD cuts the +V and just solders the ground and data. So that's what I was going to do, I just wasn't sure since it was labeled different:) Thanks again, I can't wait to finish hacking my RoboSapien. I should have it done by sometime Sunday. It's still opened up and just wait for me to solder the connections. (I also have a xbox 360 wireless controller to pc adapter coming. I can't wait to start using my controller with my robots.)
#23
Using the arduino uno rev 3.0 does not seem to be sending the ir commands. Im wondering if the ir commands are different then from version 1.0. Anyone have any ideas on this?
#24
V1 and V2 are supported by ARC and the EZ-B. I would assume the commands for movement are the same.
Have you tried with an EZ-B and ARC or only the Armadillo?
