Arduinocoms icon Arduinocoms — EZB v4-Arduino I2C bridge for ARC: supports custom C# code and reads gamepad or Wii controller inputs for robot control Try it →
I think I would change the resolution to something that would be usable on a 13 inch screen. 1920X1080 would probably still be too small. I bet at 3200x1800 your text must be tiny on pretty much anything.
on my samsung 500t it has 11.6 screen, and i use 1024 x 768 and all works fine. in fact i just found a bug in ARC on hp display at 1920 x 1080. got to take screen shots...
j
Thanks, that helped with text sizes in general on my computer, but it didn't help with ARC.
u could try zooming in like u would on an iphone.
#15
I am soooo jealous. I wanted that combo laptop:D It looks very nice.
#16
I figured it out! As TechnoPro said
  1. Open control panel.
2.Go to appearance and personalization
3.Select display.
then instead of changing text size do this:
  1. Check the "Let me choose choose one scaling level for all my displays" box
  2. Select a size based on whatever works
I used Larger - 150% which fixes the problem with the text being cut off. I had to turn down the resolution though because everything was tiny.
To adjust the resolution
3.Select display.
  1. Select Screen Resolution
  2. Change the resolution to whatever works for you! (I changed it to 1920x1080)
(Doing this just to make it really easy because I hate when forum answers are vague)
