Serial Terminal icon Serial Terminal — PC and EZB serial terminals for ARC: connect, monitor and send text/ASCII to serial devices. Supports COM, flow control, baud, DTR/RTS, hex Try it →
richard r is correct!
j
"Auto arrange new control" and "Auto open configuration after add"? How is that going adjust the size of the window?...
@Johnnybib... Just like regular windows... grab the border(s) with your mouse and resize the window to your liking.... There might be other ways, but one way is to reduce your screen resolution and that will increase the font size....
Johnny, now that is a resolution we have never tested with! I don't know anyone with a resolution that high:) We've never come across a user with that resolution before. It will take a bit before we have the time to tackle this for you, sadly.
It is added to the list:)
Are you using multiple monitors through display port or a 4d monitor?
I'm using my Lenovo Yoga 2 laptop, so only 1 monitor. Also there is no way to grab the borders of the control windows (Floor map, Add control, Script) to resize them. I have tried reducing the resolution. It makes everything larger, but the buttons are still cut off.
You have 3200 x 1800 res on a laptop... Wow....
Johnny, some controls do not have the ability to be resized - which is on purpose. Again, adding support for dpi adjustment of that super high resolution is added to the list. We don't have the time to do it immediately because there are many other items on the list.
I imagine you deal with this issue often:)
It's on the list!
which model of Lenovo Yoga 2 laptop with13.3" FHD LED Backlit Multitouch (1920x1080)?
j
