ADC Value icon ADC Value — Display ADC port voltage and 0-255 linear values (0-3.3/5V); configurable board/port, units, multiplier and sample interval. Try it →
here the video how he does it.more details from this you will have to ask dj.
good morning maybe I can not explain very well ... I enclose a photo x understand ..... I already work with robots yaskawa (motoman) and it works like this: there is a program and performs line indicates to righae then if I want the cycle begins again .... I do not find in ARC a window where I show the sequence of actions to be done to run a revolution are jd..mi explain a little better?
i made two pics.first pic the action .
second pic is the page where you can make a script.you see ubove cheat scheet. below that you can choose action and you can choose when to start or end.
at the end off the cheat scheet you can choose the action
ok,thank you this evining try....... Thank you very much all toghether
excuse me..another question...if i want insert in the script the sensor..or other i insert in a manual script( 2 pic) IS POSSIBLE INSERT IN A FRAME(1 PIC)?
first pic is where you can find all info how to wright it.
second pic choose from the cheat scheet and make the script.
i choose action BOW see below and click on it.
i forgot its sayezb("hi spiddy 1 " )
