hello i'm buy revolution jd...i don't understand to create a new seguence program and to send a program to robot
manuel
PTI Lidar Plugin
— Pineapple Technology Industries Capstone plugin adds a secretive LiDAR unit to ARC for distance measurement.
manuel
Welcome to the website. The LEARN section is where you need to start.
Have you completed JD learn tutorials?
https://synthiam.com/Tutorials/Course/1
Have you visited the Activity section for new activities? https://synthiam.com/Tutorials/Course/6
Have you reviewed the Creating Your First Dance activity? https://synthiam.com/Tutorials/Lesson/52?courseId=6
hi spiddy1
do you mean making poses and send to robot?
what for are the cam pics?
yes,i visit the all tutorial.. i don't understand to create a sequence....for example.... sitdown wake up..... walking..... i'ts a small example,i don't find a windows for insert in a sequence a intruction...... Another question.......the jd play the program alone even the pc it's off? Thank you excuse me for my english i'm italian people and i don't very well enghlish language.. Manuel
spiddy1
you always need a pc or android 4.3 phone.to play with jd. the poses like sit down ,walk are allreddy made. this is what yourre looking.
if you can if you have skype i can show you there. patrick.dierckx19
i used a pc....the application in android it's ok..i used very well..my problem is a pc....for create a sequence..i understand to use add...e insert the windows fos sensor o another....i dont understand to create a sequence and jd play his self....
In the auto positioner control you create frames.... like poses... then you create actions to tie all the frames together into a sequence... For example you create a frame called "salute" you get JD into a saluting position... then you create another frame called... "hands up" (like he is being arrested)... Then if you want to you can link those two frames together with an action where JD salutes then puts his hands up.... You can make as many frames and actions as you wish...
Hope this helps
RR
is the video ubove the good one for spiddy1?
i don't have a time for test......i understand to create a frame..thank you....because i don't understand where insert a varius frame for create the sequence.....sorry.......I am not very practical... p.s the sequence send to robot play individually if pc is off.......or the pc it must be on and connecet to jd for execute usual program..?
