ok thanks. i sure wish i could be notified when someone replies to my post. i just now noticed you replied to my post i made 8 days ago:( i think you said you turned it off so we wouldnt get a lot of junk mail.
maybe if i used the RSS feed i would see that someone replied to my message? or maybe it just shows their new posting?
I just look at the New Posts on the main Forum page. It lists all new posts ordered by date (From recent to past). That way, you can see what the current active conversations are too.
I am also having problems with the speech recognition! I wrote a script called "dance please". this is what I did: Clicked on "Add control" clicked on "speech" clicked on "speech recognition" widow opened. I added the phrase: "dance please" followed by: controlcommand("dance please", scriptstart) clicked on "save"
next:
clicked on "Add control" clicked on "scripting" clicked on "script" I named the script: Dance please First line: #Gizmo does his dance routine second line: ReleaseAll() third line: I added all my servo movements (with sleep(1000) between each set of servo movements.
Ended with: ReleaseAll() clicked on "save"
I then clicked on "start" in the script window and the dance routine ran correctly. When I say " Dance please" An error window pops up that says: Window named dance please does not exsist. Can not send scriptstart.
I believe I did all the scripting correctly. Is it me or is there a bug somewhere? I also added this to speech recognition: Phrase: "What is your name" followed by: controlcommand("say", scriptstart) I wrote a script window and named it "say" I first line I wrote: say(hello my name is Gizmo) saved it. When I said "What is your name" I got the response: "My name is Gizmo". Since I have been having difficulty I wanted a reality check. Thank you
No bugs, check over and over. Look at the tutorails. You'll figure it out:)
Alrighty then. I'll do that! BTW. I had a sucess today! I got two scripts to work!!!! My first sucess! I got my bot to Say "My name is Gizmo" when I ask , "What is your name? The second, I say "Gizmo" and the bot turns his head to the left, to the right, and back to center! I realize it may not be much to advanced users, but it was such a feeling of acomplishment for me!! As Wall e would say TADA!!
haha @lostcreekstation I was exactly the same when i first said "what is you name" and he went "Waaalll-e" :) my dog was giving me weird looks cause i was bouncing around so happy :P
Im not home right now so cant test this, but i noticed you had the ControlCommand script start as "dance please" but you wrote the script as been called "Dance please" Could it be that the command is case sensitive so the lowed case "d" and uppercase "D" is mucking it up?
Oh and love the name Gizmo byt he way! my parents dog is called that, and i have Gizmo from Gremlins bobblehead on my desk at work :)
#15
gunny did the robot's voice come out of your laptop or out of your robot?
The sound came out of the laptop. But now ive purchased one of those mp3 triggers that DJ did video about so im in process of putting the sounds on that with micro SD card and then play them through speaker attached to that in wall-e.
