PCA9685 Servo Driver icon PCA9685 Servo Driver — Drive 16 servos over EZB I2C with a PCA9685 PWM controller, using ARC servo commands and hardware-timed outputs. Try it →
#42
@Richard, What motor are you using to move this turntable set? Did you get one of Vex's motors and shaft kits?
#43
Two wire 393 motors... you'll need a few more parts like a couple of 2 or 3 inch shafts, shaft locking collars and 2 x 12 tooth metal pinion gears... however, I would buy the clawbot kit too (instead of the individual parts) because you get way more parts, including 4 x 393 motors , nuts and bolts, shafts, collars, metal and lots more... You'll still have to buy the turntable and 12 tooth metal pinion gears separately (they don't come with the clawbot kit)... :)
