Joystick (Xinput) icon Joystick (Xinput) — XInput joystick skill for ARC: maps Xbox controllers to movement, servos, triggers, vibration, variables; supports analog inputs and scripts. Try it →
Organizing Components (Completely Newbie Question)
I've got 3 h-bridges and the ez-b wired up and in close proximity to each other.
I live in constant fear that I will bump one into the other and short something out.
Whats the best way to keep them separated?
Is this what a breadboard is for?
Is moving a project from a breadboard to a chassis a big deal or can you just pop the breadboard right on the top of a flat chassis? (such as is sold on this site)
On a related note, what's the best way to join multiple power wires (or any wires)? I'm sure there is some standard way to join all these wires other than twisting them together and taping them with electrical tape;)
For example, I've got a 7.2V RC battery pack that needs to be wired into my 3 bridges. What's the best way to attach one battery pack to 3 devices?
Thanks!
Are PC standoffs the same size as electronics hobby standoffs?
I used to have 10 lbs of these things back when I was a PC technician.
Most of the standoffs are similar other than length. Some have one end that is a 4-40 thread shaft and the other end will accept a 4-40 bolt. Some of the standoffs are made of nylon and other are even made from brass.
