Inverse Kinematic Arm icon Inverse Kinematic Arm — Control robot arms with inverse and forward kinematics, converting X/Y/Z positions into joint motion and reporting end-effector location. Try it →
Omnibot + OQO + EZ-B
I wanted to share the start to my Omnibot build. Turns out the OQO-02 covers the tape deck and clock hole nicely with just a bit of dremel plastic melting.
Now imagine it all painted gloss black and a small servo controlled door covering the keyboard keys? I want it to look like Omnibot's evil twin.
Some other ideas i have to put into this little guy are.
Have him and OQO run off a 12v SLA battery
Hack apart a small battery charger like my Triton 2 and be able to charge battery's. Id just say charge this battery and a little door opens for nicad's and the charger turns on or maybe a plug near his hand he can walk around holding a lipo while hes charging it?
Maybe embed a little cheap multimeter into his body where a small door opens and shows the screen?
I would welcome any ideas you guys can come up with..
Ron
Dude that's sick!
well Omni has 120 gig of memory and hes running windows 7 picture
I need to figure out a good way to polish his dome? maybe fishtank plexyglass polish?
The robot is starting to look allot better. at least closer to what i would like. The computer is in and working. The guts of the charger are in. I am waiting for servos and a new h bridge.
Netherlands
Twitter YouTube
Dude, that's a really sick project!
Sitting at work I just connected with the robot from my Android phone opened up ARC no problem. The app is called pocket cloud. It just keeps getting cooler
hello,
Did you install the pocket cloud server on the oqo?
android phone using pocket cloud / connects to oqo running the "server for pocket cloud" / thats installed in the bot. correct?
so in theory if the bot also had a cam in the eye via wall-e you can see what the bot sees on your android phone?
That is an awesome project. I wish I could hack and build with the same skill and professionalism.
