Debug icon Debug — Central ARC debug window routing logs; shows UTC date/time, Windows/ARC/skill/hardware info, version/settings, with copy and clear. Try it →
No Answer From The Pc Speaker
Hello,
today i work a little bit with the EZB Software.
I make a new Project and i added 1x "Speech Recognition" and 1x "Speech Settings"
I made a new Phrase
for Example "Hello Robot" and Command Say( "Nice to see you" )
So everything fine .. my Phrase will be recognize ( i see it in the small window) but no sound form the PC speaker ( I must be " Nice to see you")
So the easiest thing, but i dont get it!
What i do wrong?
Boris
PS:
I still work without a EZB4 Controller only Notebook + Webcam/Mic
#17
Buy a cheap set of head phones test if it works if not it's the program if it dose then it's your pc's speakers.
#18
IM SURE IT WOULD WORK CAUSE IT WORKED FOR ME WHEN ME AND SO I KNEW Tohook up some little speakers for 10$@ Walmart so I got to here again.
#19
I test it on 2 diffrent Computers.
1x Notbook with embedded Speakers
and 1x my big Desktop PC with Sound-System
so i don't think there are the speakers who make the problems.
All other Sounds are working.
#20
If your talking about the robot speakers then replace the ez bv4
#21
I Get it now so the program ARC isn't working it might need updates.
#22
I'm just trying to do as much as I can to help.
#24
For example i load the "EZ-Face script" and if the Script recognize me, the software must say "Hello - Picturename"
Fine all works, the software recognize me and say "Hello Boris" and I hear it.
Then i load my simple voice testscript , i say "Hello Robot" - Software recognize, but i hear no answer.
So i think everthing is ok, but where is the mistake?
