is it possible to get the mp3 files haunt me and i believe i can fly for some reason when i play the files ,the ezb disconnect,
— Edited
Connection Diagnostic
— Diagnose EZ-B Wi-Fi connection issues with verbose EZ-B communication logging, ping tests, log export and diagnostic reports for Synthiam support.
jd-win8-1.EZBworks perfect
am sure it not the pin,whithout using the mp3 file it
To clarify, did you upload the project that "works" or did you upload the project that "does not work"?
bolt you named are one and desame.i have two jd on win8 and win8-1
@nomad.
Just to be clear, you are using the exact same project on two different computers. One computer, the Windows 8 one, is giving you the disconnecting issue, and the Windows 8.1 computer is okay. Is that correct?
no bolt are on win8 the other is win7 i use win8 for first robot and win8-1 second robot.
So which computer/operating system are you having the problem with?
ARC win8 first robot ,this one dissconnect when trying to play soundboard dj.
i call the ARC win8 and win8-1 to keep them appart. but its one win8 laptop
