is it possible to get the mp3 files haunt me and i believe i can fly for some reason when i play the files ,the ezb disconnect,
— Edited
The Navigator
— Path-planning navigator using ARC NMS position and obstacle data to map, log trajectories, and autonomously follow waypoints.
Right, so your calling your projects Win-8 and Win 8-1. Got it. That's what was confusing me thinking you meant Window operating system "8" and "8.1". Thanks for clearing that up.
So it's the exact same project, with no changes made to it, works on Windows 7 with no problems, and does not work on the Windows 8 laptop. Have you tried fully closing down your Laptop, restarting it, and trying the project again, or even download the project from the Cloud again after the laptop restart?
i always open projects in ARC in cloud my projects.its a few days old so did some restarting .so i cann last robot win8-1.i started a new project and i used the, merge ,checkbox soundbourd and rgb from original jd from dj. this ezb works only on win8.
Sorry, I'm still a little confused where you're having the problem and calling things "win8". I still don't know if you are refering to your ARC projects "win8" and "win8-1" of your laptops operating system "Windows 8 or 8.1" .
It looks like what you're saying is you are using one Windows 8 laptop, one project works and the other does not. What you could try is to open a new project, merge the soundboard, add a new RGB animatior and program it yourself to see if that solves the problem.
Can you not just use the scan tool or manually change the EZ-B address to 192.168.0.1:23 in the original JD project?
i have 3 jd's to hold them appart i gif them a name in ez builde,excample jd1 is windows7 jd2 is windows8 jd3is window8-1 but is same laptop with windows 8.1 on it
i try ARC jd original 192.168.1.1:23 scanner dont find any ezb when i use still the original jd ARC 192.168.0.1:23 it connect but , jd doesn move.
when i take my project it connects and move all poses,but not soundcard then it, disconnect also on my iphone,
A shot in the dark, but worth looking at. The JD that keeps disconnecting... check the i2c cable for the RGB array to make sure it's properly and securely connected, and that it's not damaged or twisted in any way. The slightest problem with i2c, and it can cause the EZ-B to disconnect.
jd number 3 has not a head sofar,i just order it. so that can be the problem.
If your running an RGB animator without an RGB light panel, that probably is the problem and why it disconnects.
ok i check that and report back here. i remove the rgb and try to play the song.
