TCP Clients icon TCP Clients — Monitor incoming TCP Server connections when TCP Server is enabled under Connection > Config; view and track live connections. Try it →
Mobile App And Movement Panel(s)
Mobile App And Movement Panel(S)
So I have built a mobile app that works great. I have a custom Movement Panel set up in ARC that controls my robo claw "h-bridge"for movement of its tracks. For movement of my robots shoulders I have used a second robo claw as I have used wheel chair motors for those as well, and a third robo claw for body up/down using a linear actuator. The second and third roboclaw were easily used by using script commands in speech recognition. So in other words I can say robot raise right arm and his right arm moves.
Now the problem. I would like to add the shoulders, and body up down to my mobile app. It seems as though the mobile app works directly with a Movement Panel and unfortunately it seems I am only allowed one movement panel? I would also like to be able to control his head pan and tilt which operate off of "standard" servos. Any ideas how to get around this?
                                             Thanks          Chris
#17
There are no errors in the cloud error log. Nor are there any errors in the website for attaching files.
Perhaps you can provide details step by step of the process so we can ensure you're not missing anything. Sometimes simple things can be overlooked:)
#18
Sure. I have my ARC file sitting on my desktop. Its name is B2K mobile. I select the "browse" function located under Attach File, and above upload file. When I press the upload file button after browsing and finding my file the taskbar at the top of my computer says waiting for ez robot, and then says "page cant be displayed".
#19
When saving my project to the cloud it says Saved! but I cant find it anywhere. Im trying to find a way to screen capture this.
#21
Try it within ARC... Open your app in ARC.... Select File at the top of screen... You have the option to save to your PC (left save button) and the option of saving to the cloud (right save button).... I am thinking you might have been saving it all along to your hard drive instead of the cloud?
I just tried the above and it worked for me... I created a sample mobile app, uploaded it to the cloud... Moments later I downloaded it to my Samsung S3... Works great...
#22
OK, I see you have... disregard my last post...
#23
Yeah thanks Richard! For whatever reason its not there on the cloud. Ive sent it many many times now. The GUI does work from my laptop PC. And I am glad I saved it. Thanks guys Chris
#24
Can you save regular projects (and retrieve them) to the cloud? When I browse the cloud with my Samsung, I see all my projects saved there, not just my mobile ones... Try saving a test app then download back to your PC... save it again and try to then use your Android to download it....
