Hi would it be possible to make a mind contromm robot or incorparate this technology. https://emotiv.com/
— Edited
5 Participants
EZB Connections
— Add and manage up to 255 EZ-B I/O controller connections in ARC, select COM/IP ports or device addresses to connect or remove devices.
oh no - not this again
There's no such thing as mind control. I'm the first person to really wish it existed - and we've spend thousands of dollars on hardware for experimentation, just to find out that it's a hoax ripping people off. These so called "mind control" devices pretty much read the connectivity of your skin by the amount of sweat and temperature. So, when you "focus real hard", you're modifying the conductivity and heat and stuff which makes the sensors return a value.
If you purchased a mind control sensor, feel free to add our SDK to it - or link the ARC up to it and let us know your experience. Who knows, maybe someday there's a diamond in the ruff that the entire world doesn't know about which actually reads minds.
If a real mind control device existed, there's plenty of paralyzed individuals who would be first in line.
thanx i was going to get one if it would work with the robots,
ps: loving the features already available
also how would i attach normal moters onto the ezb and what controls would i use for it. i want it to wheel around and be like a quad copter
If you mean "motors" for a wheeled robot you can use an H-Bridge... see here... H-Bridge motor controller or a Sabertooth (Google it) motor controller... If you are using it for a quad copter then you use BEC/speed controller to drive the propellers...
If you want a simple wheeled robot like Adventure Bot (in the store here) you can use 360 deg servo motors that plug directly into the ezb's digital ports...
thanx
hi does anyone know if i could kepe 2 wheels, and have my robot giro stabilised like the mip robot
EZ Robot has that covered too... Inverted Pendulum
