Ohmnilabs Standalone icon Ohmnilabs Standalone — Connects Ohmnilabs Telepresence robot's UP Board COM to ARC, enabling drive and servo control (neck V0) and integration with ARC cameras. Try it →
Mavlink Autopilot Rtk Configuration
I have a question about the Mavlink Autopilot robot skill in ARC (ARCx). This skill is new, and when I added it it did not populate the hardware product list for selecting a Pixhawk autopilot. Is there a place in this robot skill where you can input base-station RTK feedback for GPS corrections?
Specifically:
  • I know there are two different kinds of RTK feedback (one is stationary - I’m not sure of the exact name of the other).
  • There is also a base station that can send corrections over a radio link. Is there a field or configuration area in the Mavlink Autopilot robot skill to provide that information?
For context, my goal is to have ARC control my Mavlink autopilot (Pixhawk) and work seamlessly alongside QGroundControl. I’m using the Mavlink Autopilot robot skill in an ARC project - I haven’t specified how the Pixhawk is connected yet (direct USB/serial to the PC or via an EZB). If it matters, please let me know what connection details would be helpful to provide.
Mavlink Autopilot by Synthiam Inc
ARCx MAVLink autopilot control for Pixhawk/PX4/ArduPilot: drive, nav, obstacle avoidance, geofence, and mowing planner with simulation.
Will I be able to use EZ-B v4 with this Mavlink Autopilot system? I am already familiar with them and they give many inputs and output as well as many other nice features.
Yes - you can absolutely use an EZ-B v4 alongside the Mavlink Autopilot robot skill in ARCx.
How they work together
The Mavlink Autopilot skill is the movement panel for the vehicle, while the EZ-B v4 can handle everything else ARC is great at:
  • servos
  • sensors
  • audio / speech
  • custom logic
  • camera skills
  • digital I/O
  • PWM
  • I2C / UART peripherals
So a very common setup is:
  • Pixhawk / flight controller handles stabilization, navigation, and vehicle control
  • EZ-B v4 handles payloads, turret servos, sensors, lights, voice, etc.
  • ARCx coordinates it all
RTK corrections
The RTK part is handled in the Rtk Gps robot skill, not inside Mavlink Autopilot itself.
ARCx’s RTK support includes:
  • NTRIP caster corrections
  • base station mode
  • rover mode
  • RTK fixed / float handling
If your goal is GPS correction for the Pixhawk, the usual approach is:
  1. Add Rtk Gps
  2. Configure it for your receiver / corrections source
  3. Let Mavlink Autopilot consume the autopilot’s telemetry/mode/movement
  4. Use QGroundControl in parallel if you want
RTK terminology you mentioned:
  • Rover = the vehicle receiver
  • Base station = stationary receiver sending corrections
  • RTK fixed = the high-precision state
  • RTK float = valid corrections, but not yet fully fixed
About the Pixhawk hardware list
If the Mavlink Autopilot skill didn’t populate a hardware product list, that’s not unusual if the connection isn’t configured yet or if it’s expecting the MAVLink device details rather than a "product list" like an EZ-B skill would.
The important part is usually:
  • connection type: USB/serial, telemetry radio, UDP/TCP, etc.
  • baud rate if serial
  • whether QGroundControl is also sharing the link
Best-practice setup
If you want ARCx + Pixhawk + QGroundControl + EZ-B v4, the cleanest architecture is:
  • Pixhawk = flight controller
  • Rtk Gps = RTK receiver / correction handling
  • Mavlink Autopilot = ARCx Movement Panel and mission control
  • EZ-B v4 = auxiliary robot hardware
That’s the proven way to do it instead of trying to force everything through one skill.
Helpful reference
What I need from you
To give you the right setup steps, what are you trying to accomplish overall?
For example:
  • rover / mower / boat / drone?
  • do you want Pixhawk to drive, or just provide telemetry while ARC controls payloads?
  • is your RTK receiver connected to the Pixhawk, the PC, or the EZ-B v4?
  • are you planning to share the MAVLink link with QGroundControl at the same time?
If you share your exact connection path, I can tell you the recommended ARCx wiring/configuration layout.
You do not need to use the RTK GPS robot skill since you already have the software on the robot. Your question merges two robot skills but they're seperate things and entirely unrelated.
Mavlink Autopilot is what you want to use, answered by me in your other thread.
You do not need any gps robot skills. The only robot skill you need is the MavLink Autopilot. It uses all of the sensors and computing of the existing firmware of your lawncare product. If you are to ask another question, specifically ask about Mavlink and do not mention the RTK GPS robot skill because you have no reason to use both together.
I recommend printing the Mavlink Autopilot manual and giving it a read.
Ok understand, I think that I used wrong words to describe the base station. The base station is using RTK for corrections. This is all somewhat new to me the different types of software and sensors for locations. Finally got rover moving this morning with waypoints so it's a little encouraging. There are so many variables that have to be perfect to make it work. Will take a little while to digest all of this new information.
That makes sense - and getting the rover moving with waypoints is a big milestone. Nice work.
You’re right: there are a lot of variables in the MAVLink/RTK/GPS stack, and it can feel like several systems are all talking at once. The good news is that once the Pixhawk + MAVLink Autopilot path is working, ARCx can sit on top of it cleanly without needing separate GPS skills.
The key idea
For your setup:
  • Pixhawk / autopilot firmware handles the navigation and RTK/GPS side
  • Mavlink Autopilot in ARCx talks to that firmware
  • QGroundControl can still be used alongside it for calibration, tuning, mission work, and telemetry
  • EZ-B v4 can be added for servos, lights, sensors, audio, and other robot hardware
Important clarification
There usually is not a separate field in the Mavlink Autopilot skill where you manually type in "base station RTK correction settings" the way you might expect in a generic GPS skill.
Instead, the RTK/base-station side is typically configured in the autopilot / GPS hardware / companion GNSS system itself, not in ARCx.
So the workflow is usually:
  1. Get the autopilot and GPS/RTK hardware configured correctly
  2. Confirm the vehicle reports valid GPS/RTK status
  3. Connect ARCx with Mavlink Autopilot
  4. Use QGroundControl if needed for flight controller setup and parameter tuning
Why this matters
ARCx is not replacing the autopilot’s GPS stack - it is driving and coordinating with it over MAVLink. That’s why the skill is focused on modes, arming, missions, hold, return home, pose, and movement commands rather than base-station setup.
A good next step
If you want, I can help you narrow down the exact ARCx setup based on how your Pixhawk is connected:
  • USB to the PC
  • Telemetry radio
  • Wi-Fi / network UDP
  • Through an EZ-B / companion computer path
And if you want to keep moving forward without getting buried in the terminology, I can also help you make a simple checklist for:
  • Pixhawk connection
  • MAVLink Autopilot skill setup
  • QGroundControl coexistence
  • RTK sanity checks
What exact hardware are you using for the GPS/RTK side, and how is it connected to the Pixhawk?
@Athena, good to know that you will be able to communicate with it. For now I need to concentrate on getting the rover communicating properly and going to waypoints with 2 cm of accuracy. I am getting somewhat fluent with it all but there are so many strange software issues that seem to arise. You don't know what you don't know. After I get all of that working will be back with you to connect all the features of ARCx. I've got the mechanical side of things under control so this will be fun!
That’s a solid plan - get the navigation stack reliable first, then layer ARCx features on top.
For 2 cm accuracy, the big thing is that the RTK/GNSS side, Pixhawk parameters, and mission setup all have to agree. ARCx can work alongside that very well, but the precision comes from the autopilot + RTK system, not from ARCx itself.
What to focus on next
  • Confirm RTK fix status on the Pixhawk/GNSS side before trusting waypoints
  • Make sure the base station / rover pair is correctly configured
  • Verify the coordinate frame / datum you’re using for missions
  • Tune any waypoint acceptance radius, loiter radius, and navigation parameters in the autopilot
  • Test in a very open area first, then tighten things up
Good sign
If you’re already getting it to move to waypoints, that means the hard part is underway. The remaining work is usually:
  • fixing edge-case connection issues
  • stabilizing the GPS/RTK lock
  • tuning mission behavior
  • sorting out any protocol or serial/network quirks
ARCx when you’re ready
When you come back to ARCx, the Mavlink Autopilot skill should let you:
  • drive the rover
  • start/pause/resume missions
  • coordinate with other robot skills
  • keep QGroundControl in the workflow
A practical tip
If you run into "strange software issues," try to isolate them one layer at a time:
  1. GNSS/RTK hardware
  2. Pixhawk / firmware
  3. MAVLink connection
  4. QGroundControl
  5. ARCx Mavlink Autopilot
That makes it much easier to tell where the problem actually lives.
If you want, when you’re ready, I can help you build a clean ARCx + Pixhawk + QGroundControl setup checklist so you can add the ARC features without destabilizing the waypoint system.
What platform are you using for the rover navigation - ArduPilot or PX4?
