Inverted Pendulum icon Inverted Pendulum — Balancing controller for Sainsmart v3 (and compatible) robots: PID tuning, real‑time telemetry, angle offset, movement and calibration via ARC. Try it →
Resolved Resolved by Jeremie!
Looking for compatible EZB camera cable
Looking For Compatible EZB Camera Cable
Does anyone know of a cable I could buy domestically to the US with connectors that is compatible with the EZB camera port? I'd like to find a vendor that has cables like this that can ship to or within the US quickly.
I know I can order directly from EZ Robot but the last time I ordered these cables from them they took weeks to arrive. I really don't want to wait that long.
I've already set up 2 of 4 EZB's in my robot to connect to the computer through USB using the camera port. I want to go ahead and convert the other two.
As an alternative I can just buy connectors and pins and make my own. What are the specs on these connectors.
Quote:
EDIT, I mistakenly stated this and have removed. I was looking at the wrong measurement. Please ignore: EZ Robot site says 1.5mm. Is that the pin spacing? So would I look for a 1.5mm, 6 pin connector? But what type?
See post # 7 for the correct size and pitch. Thanks Jeremie.
Thanks!
Camera Device by Synthiam
Use PC or robot cameras for vision tracking: color, QR, glyph, face, object, motion; record video/data, control servos and movement, run scripts
#17   — Edited
Hey everyone, thanks for all the help. Herr Ball is sending me camera cables he got from EZ Robot that has been setting around his house. Thanks Herr! I hope you find something it fill that empty space now. LOL!;)
I also found a couple 2.0 PH connector kits on Amazon that has pre crimped pins attached to wire. Don't need them now that Herr saved the day for me but it's good to know for feature projects. Here is is:
This one has both male and female PH 2.0 connectors sized from 2 pins to 6 pins. This has pre crimped wires that just snap into place - $19.00 USD (No crimpers needed). Good for making extension cables! The down side it that it only goes up to 6 pins if you need more but the EZB connectors only has 4p and 6p male connectors (or female depending how you ID. LOL.xD).  Male/Female PH 2.0 Connector Pre-Crimped Cable Kit
If you plan on doing a lot of these a crimping tool and a bare kit is probably the way to go. The kits like Sleepy points to has a better selection of sizes. With either option you can make these as long as you need. Just with the pre cut and pre crimped kit I pointed to You you would have to simply solder a longer wire in the middle and your desired connector choice (If needed) on the other end from the 2.0 housing. If you don't know how to solder may it's a good skill to learn. It comes in very handy if your building robots and easy to do once you learn. Sorry if I sound like I'm lecturing.
Defeat long shipping times! There is one day shipping on this item to my house in the USA with Prime! I don't know how that works in other parts of the country or the world. Don't we live in marvelous times??!!
