Relative Servos icon Relative Servos — Synchronize servos by designating a master; slave servos mirror scaled (decimal/negative) positions with min/max limits and pause control Try it →
Resolved Resolved by Jeremie!
Looking for compatible EZB camera cable
Looking For Compatible EZB Camera Cable
Does anyone know of a cable I could buy domestically to the US with connectors that is compatible with the EZB camera port? I'd like to find a vendor that has cables like this that can ship to or within the US quickly.
I know I can order directly from EZ Robot but the last time I ordered these cables from them they took weeks to arrive. I really don't want to wait that long.
I've already set up 2 of 4 EZB's in my robot to connect to the computer through USB using the camera port. I want to go ahead and convert the other two.
As an alternative I can just buy connectors and pins and make my own. What are the specs on these connectors.
Quote:
EDIT, I mistakenly stated this and have removed. I was looking at the wrong measurement. Please ignore: EZ Robot site says 1.5mm. Is that the pin spacing? So would I look for a 1.5mm, 6 pin connector? But what type?
See post # 7 for the correct size and pitch. Thanks Jeremie.
Thanks!
Camera Device by Synthiam
Use PC or robot cameras for vision tracking: color, QR, glyph, face, object, motion; record video/data, control servos and movement, run scripts
hi dave
i think its an jst 6pin connector . but there are many type's .
Dave
I have some here, they are 8 inches long and plug into the EZB4/v2 camera port. Send me a email (address in profile) if you are interested.
You're awesome. I'll accept. Can't send email right now. I'm out and about. Later for sure. Thanks
I plan on making my own extended camera cable with the parts yo see above. I found the 6pin  female end easy at local electronic store. But had to buy a whole connector kit just to get the 6pin male connector. The flat gray phone cable, is something I use at work. I will be making a 24 inch long cable. If some one wants one, let me know:)
@Dave
Didn't hear from you, are you still in need of the cables or did you happen to find some?
hi robohappy
i think yours are different .they have a tiny edge witsch the original dont have .
#7   — Edited
Hey @Dave that type of JST connector is called JST-PH, you can find the connectors and pins on amazon. Some kits have pre-crimped wires, others require that you crimp your own. If you need to crimp your own, you'll need to spend the extra $ on a crimper.
#8   — Edited
Herr Ball. Sorry, I had double hernia surgery today. I've been kinda out of it and pre occupied before that. I'll send a message as soon as I can. I'll still feeling kinda loopy.lol. I appreciate this. And thanks Jeremie, I'll look into this.
