Waveshare Bus Servos icon Waveshare Bus Servos — Control Waveshare servos (TTL/RS485): set position & speed, release torque, read position. RTS option for converters; reverse-engineered protocol. Try it →
#17
i give up on this. i will do other stuff instead. Any ideas?
#18
I posted a link to one a while back, here it is again Linky Link Link
While I'm not 100% sure it's the right thing I am 99% sure.
It's 5 pin, but only 3 are needed;
Quote:
Pin 1 RX(m) Signal in non-inverted Pin 2 TX Signal out controlled by software Pin 3 +5V Power Pin 4 RX(232) Signal in inverted for direct connection to RS232 Pin 5 GND Ground
Wire a servo extension as follows; Black to pin 5 Red to pin 3 White to pin 1 or 4 (unsure which, it could be either)
Wait for someone to confirm before buying, I wouldn't want someone to get the wrong thing from something I've said.
