Dj, what serial lcd screen did you use for you omnibot 2000?
Is there a brand of lcd you especially like/use?
Also, all i can find is i2c serial lcd screens when i search serial lcd screens on ebay. ?
Ubtech Alpha 1 Bluetooth
— Bluetooth control for UBTech Alpha1 servos via ARC: map Vx to servo IDs, enable servos, and integrate with ARC movement & LEDs.
It's a tv lcd from a car headrest connected to an ipod
oh... but u have mentioned lcd screens. im a little confused because of "i2c serial lcd screens". Do you have a tutorial on lcd screens at all? thinking of putting one in the front of my wall-e when im done phase 1.
Do you have a pic of the setup for your lcd?
Thanks.
On the top menu is an open titled "Tutorials"
For things like screens, that's hardware. Look under the hardware tab.
Here is a shortcut: https://synthiam.com/Tutorials/Hardware.aspx?id=13
Dj they all say i2c serial lcd displays. ?
found this one. this is a serial lcd?
www.ebay.ca/itm/NEW-ARDUINO-12-DIGIT-7-SEG-SERIAL-LCD-Display-MODULE-with-example-SKETCH-/181054678711?pt=LH_DefaultDomain_0&hash=item2a27b326b7
There is also this one. is this one right?
www.ebay.ca/itm/1-8-Serial-SPI-Interface-TFT-Color-LCD-Module-Display-128-x-160Dots-/170856821451?pt=LH_DefaultDomain_0&hash=item27c7dc32cb
There are two different items that both can be referred to as LCD displays.
They both work differently. Typically the second type need a video input through VGA or composite (or possibly HDMI these days?). The EZB cannot output anything to this type of screen.
There are the smaller LCD displays which are Serial or I2C, I've yet to source a serial one to fit my current project but I2C are all over eBay. Be wary of which one you get and search on here first as the one I bought was useless as it had no decent documentation.
You can use either Serial (3 wire, connects to Digital Port) or I2C (4 wire, connects to I2C Bus). I2C is more complicated than Serial, at least to me it is...
again, they say i2c serial display!?!
Not exactly 100% sure if this is right, LCD Displays are kind of fuzzy to me but hoping someone will confirm/correct me...
https://www.ebay.co.uk/itm/Serial-LCD-Display-Module-16-x-2-BV4109-controller-fitted-/310562419652?pt=UK_BOI_Electrical_Test_Measurement_Equipment_ET&hash=item484ef673c4
That should be a simple serial LCD.
