#17
I added a full C3PO JD front body incase anyone wants one. It mounts to the standard JD body back. It's just like the standard front JD body part, the only thing that changed in the design is the very front and obviously there is no longer an EZ-bit clip on the front.
JD C3PO full front body
#19
@JustinRatliff You've been doing some awesome work lately. Any chance of coming up with a "backpack" cover for JD to go over the EZB-V4 and wiring?
i would vote too for a backpack, and, if not asking too much a female clip & play ....
#21
Just a general backpack for JD? Or C3PO themed? I guess If I made a general back pack cover I could make themed ones as well.
@ptp, I can't invision a female clip and play piece, what would it look like? There is the female plate, is that what you meant?
Female clip plate
yes (female plate) or something similar to the JD Front body
#23
@ptp, you mean a female slot on the backpack for JD?
I thought you meant a female clip in general at first, but I think I follow your idea now. ;)
yes, female slot in the backpack
