I created a couple of C3PO themed parts for JD. A modified front face and a chest plate that can be clipped on the front of JD.
Thingiverse JD C3PO Head Thingiverse JD C3PO Chest ClipLet me know what you think.
awesome! I'm going to print out this weekend!
What CAD software do you use?
Great job !
thats cool,how does the two head parts comes together. with screws ?
also the chestclip is that for original chest ? or is the a new modified chest too ?
@DJ I hope you like it! I use https://www.tinkercad.com/ primarily and Simplify3D to finalize the .stl
@Nomad, that is correct. I modified the standard JD head, which is two parts (front and back) so this is a C3PO themed front and the screw holes are still there, along with the camera mount.
I hope you all like them. I'm planning to do other themed clip on chests and JD front face plates. I just printed a JD/Mini Me clone head from a 3d scan of my face. Once I clean it up, I'll post a picture of it so you can see the results.
looks really good.the chestplate does it have openings on the side and bottom ? cant wait to see pics off mini jd and the other parts.
love it
@Nomad, the chest clip just slides in the standard JD slot opening that is already on JD's chest.
I could have designed a whole new front, but it seemed like a waste when JD already has a clip.
yes i can see that.but i think the plate will stand some 8 mm off the chest jd. withs is a lot .maybe its better to check this. the slot jd chest is some 5 mm include 3mm off the clip on the plate.
