Custom Movement Panel icon Custom Movement Panel — Custom Movement Panel maps directional commands to scripts, adjusts per-wheel speed (0-255), and integrates with joysticks for unsupported motors Try it →
#17
@Richard - Mine is the USB version, I will check the baud rate immediately. I assumed since it was blinking green it was communicating. RX to TX. I'll let you know.
#18
I just bought the new USB version.... Check the PDF manual for it... It will show you how to change the baud rate... I think by default it is set at 9600...
#19
Yup, it was baud. The instruction said a blink green means it received the packet properly so I thought I was good. Thanks for the suggestion.
