ok. select from drop down menu in camera list and see what ip is to the right of it.
Click in the box I have highlighted red, the long one with EZB://192.168.0.234 in it. Manually change this to your EZ-Bs IP address. Click Start.
Have you done that?
Before you ask any further questions or think about anything else try the above.
Do not over complicate this simple procedure.
The ip address that is listed to the right of the camera device has to be the same as the ezb4 address, the one you scan for in the initial power up of ezb4 controller
Thank ALL of you.
I was doing the procedure correctly except for ONE little thing. I was giving the IP address a "" instead of a"/".
Working now like a charm.
Thanks again.
See how easy it is if you don't over complicate things?..
14 posts (15 including this one) yet the actual solution was in post #2 (despite credit for the solution going to a different post from the looks of things...)
#15
Yes Rich, but, I want you to know that I am really trying hard. My brain is simply wired that way since my stroke and it is getting worse the older I get. But, I still try. I have absolutely no control over the MONSTER that has taken over my Brain. sorry.
#16
Don't worry Mel, we'll get ya through this. As long as Rich & Richard are willing to stick around and help I don't think many of us will float off with the tide. I understand your frustration. I have special needs also; most of the time I think I know better then everyone else and end up doing something completely stupid. However I don't have an excuse like a stroke. I'm just hard headed and think every fix is more complex then it really is. When something happenes I cant figure out I have to keep telling myself to "just start at the beginning". :P
