Custom Movement Panel icon Custom Movement Panel — Custom Movement Panel maps directional commands to scripts, adjusts per-wheel speed (0-255), and integrates with joysticks for unsupported motors Try it →
How To Use Bing Speech Recognition With Python
Hello Athena,
Is it possible to send a query through Bing Search and then receive the results in my Python script? I'm looking to integrate these search results into my project using Synthiam ARC. Could you provide some guidance on how to achieve this integration?
Thank you!
EZ-B Iotiny by EZ-Robot
Servos 8
ADC 2
Digital 8
ChatGPT chatbot for robots with memory, image description, personality scripting, and voice conversation via OpenAI API
@ Athena what is the wrong with the followig code import socket
Configure connection details
EZB_IP = "192.168.1.1" # Replace with the EZ-B's IP address EZB_PORT = 23 # Default Telnet port
try: # Create a socket ezb_socket = socket.socket(socket.AF_INET, socket.SOCK_STREAM)
# Connect to the EZ-B
ezb_socket.connect((EZB_IP, EZB_PORT))
print("Connected to EZ-B!")
# Example command (send and receive data)
# Replace with EZ-B specific commands if needed
ezb_socket.send(b"ExampleCommand\r\n")
response = ezb_socket.recv(1024)
print(f"Response from EZ-B: {response.decode()}")
# Close the connection
ezb_socket.close()
print("Connection closed.")
except Exception as e: print(f"Error connecting to EZ-B: ")
The code you provided is a Python script intended to connect to an EZ-B IoTiny using a socket over Telnet. Let's go through the code and identify potential issues:
  1. IP Address and Port:
    • Ensure that the EZB_IP is correctly set to the IP address of your EZ-B IoTiny. The default IP address 192.168.1.1 is typically used when the device is in AP mode. If your device is in client mode, it might have a different IP address assigned by your router.
    • The port 23 is correct for Telnet.
  2. String Formatting:
    • The print statements should have their strings enclosed in quotes. For example, print(Connected to EZ-B!) should be print("Connected to EZ-B!").
  3. Command Formatting:
    • The command bExampleCommand\r\n should be replaced with an actual command that the EZ-B IoTiny understands. Ensure that the command is correctly formatted and terminated with \r\n to indicate the end of the command.
  4. Error Handling:
    • The error handling is correctly implemented with a try-except block. However, ensure that the exception message is informative enough to help diagnose connection issues.
  5. Code Example with Corrections:
    import socket
    # Configure connection details
    try:
        # Create a socket
        # Replace with EZ-B commands if needed
        ezb_socket.close()
        print(f"Error connecting to EZ-B: {e}")
  6. Additional Considerations:
    • Ensure that your network allows Telnet connections and that there are no firewall rules blocking the connection.
    • Verify that the EZ-B IoTiny is powered on and connected to the network.
If you continue to experience issues, please provide more details about the error message or behavior you're encountering, and I'll be happy to assist further!
@Athena Following errors occured on  executing import socket
ezb_socket.close()
error occured: Connected to EZ-B! Response from EZ-B: Error #1002: You do not appear to be a valid ARC instance. Closing Connection! Connection closed.
The error message "Error #1002: You do not appear to be a valid ARC instance" indicates that the EZ-B IoTiny is expecting a specific type of connection or command that it recognizes as coming from the Synthiam ARC software. Here are some steps you can take to resolve this issue:
  1. Verify Command Format:
    • Ensure that the command you are sending (b"ExampleCommand\r\n") is a valid command that the EZ-B IoTiny can process. You may need to refer to the EZ-B IoTiny documentation or Synthiam ARC's command set to find the correct command format.
  2. Use Synthiam ARC:
    • The EZ-B IoTiny is designed to work seamlessly with Synthiam ARC. If you are trying to control the EZ-B IoTiny, consider using ARC's built-in features and scripting capabilities. This will ensure compatibility and avoid protocol issues.
  3. Check for Authentication:
    • Some devices require authentication or a specific handshake to establish a connection. Check if the EZ-B IoTiny requires any initial setup or authentication before accepting commands.
  4. Use ARC's API:
    • If you want to integrate Python with Synthiam ARC, consider using ARC's API or scripting capabilities. You can write scripts within ARC using JavaScript or Python, which can interact with the EZ-B IoTiny directly.
  5. Review Network Configuration:
    • Ensure that your network configuration allows for proper communication between your computer and the EZ-B IoTiny. Check for any firewall or network settings that might be blocking the connection.
  6. Consult Documentation:
    • Review the EZ-B IoTiny and Synthiam ARC documentation for any specific requirements or examples of how to send commands to the device.
If you need further assistance with integrating Python scripts within Synthiam ARC, feel free to ask!
These errors occur because you're asking a question that doesn't make sense. You're purposely making the effort to work around all of the fantastic components that will make your programming easier. You're avoiding everything provided to make your robot easier to program. You are not advancing at an average pace by circumventing the robot's skills and not following its detailed manual. If you follow the manual and some examples, your robot will be completed by now.
Here is the Bing speech recognition robot skill manual: https://synthiam.com/Support/Skills/Audio/Bing-Speech-Recognition?id=16209
All Bing Speech Recognition system responses get processed in the "All Recognized" script. In that script, you can choose to use JavaScript or Python.
@Athena explain to how to use the bing speech recognition robot skill.
Certainly! The Bing Speech Recognition robot skill in Synthiam ARC allows you to convert spoken words into text using Microsoft's Bing Speech Recognition service. Here's a step-by-step guide on how to use this skill effectively:
Setting Up Bing Speech Recognition
  1. Add the Skill to Your Project:
    • Open your ARC project.
    • Click on the Project tab and select Add Control.
    • Navigate to the Audio category and add the Bing Speech Recognition skill.
  2. Configure the Skill:
    • Phrase List: Add phrases that you expect the robot to recognize. This helps improve recognition accuracy.
    • Not Handled Script: This script executes when a detected phrase is not in the phrase list.
    • All Recognized Script: This script executes for all detected phrases. You can use this to process any recognized speech.
    • Start Listening Script: This script executes every time the robot skill begins listening.
  3. Variable for Recognized Speech:
    • The recognized text is stored in a variable (default is $BingSpeech). You can access this variable in your scripts to determine what was spoken.
  4. Auto Record Using VAD:
    • VAD (Voice Activity Detection) automatically starts and stops listening based on detected speech. Enable this if you want the robot to listen automatically.
  5. Auto Record Using Wake Word:
    • Set a wake word that the robot will listen for before starting to recognize speech. This is similar to how smart assistants like Alexa work.
  6. Control Commands:
    • Use control commands to start or stop listening programmatically. For example:
      ControlCommand("Bing Speech Recognition", "StartListening")
Example Usage in JavaScript or Python
Here's an example of how you might use the Bing Speech Recognition skill in a script:
# This script runs every time speech is recognized
recognized_text = getVar("$BingSpeech")
# Check if the recognized text matches a command
if recognized_text == "turn on the light":
    # Execute a command to turn on the light
    print("Turning on the light")
    # Add your command here
elif recognized_text == "turn off the light":
    # Execute a command to turn off the light
    print("Turning off the light")
else:
    print(f"Recognized: {recognized_text}")
Additional Tips
  • Microphone Setup: Ensure your microphone is set up correctly. Use the Setup Microphone option to configure it.
  • Language Support: Choose the appropriate language from the drop-down menu if you are using a language other than English.
  • Testing: Test different microphone placements and gain settings to optimize recognition accuracy.
By following these steps, you can effectively use the Bing Speech Recognition skill in your ARC project. If you have any more questions or need further assistance, feel free to ask!
@Athena i have downloaded one robot skill which is written in C# .net but on executing the code it gives error "EZ_Builder library is missing"
It seems like you're trying to work with a custom robot skill written in C# for Synthiam ARC and encountering an error related to the missing EZ_Builder library. Here's how you can address this issue:
Steps to Resolve the Missing EZ_Builder Library Error
  1. Ensure Proper Setup:
    • Make sure you have the Synthiam ARC software installed on your computer. The EZ_Builder library is part of the ARC environment, and having ARC installed is essential.
  2. Check the Robot Skill:
    • Verify that the robot skill you downloaded is compatible with the version of ARC you are using. Sometimes, skills may require specific versions of ARC or additional dependencies.
  3. Include the EZ_Builder Library:
    • If you are developing or modifying a robot skill in C#, ensure that your project references the EZ_Builder library. This library is necessary for interacting with ARC and its components.
    • You can typically find the EZ_Builder.dll file in the installation directory of Synthiam ARC. Add this DLL as a reference in your C# project.
  4. Rebuild the Project:
    • After adding the necessary references, rebuild your C# project to ensure that all dependencies are correctly linked.
  5. Check for Updates:
    • Ensure that both Synthiam ARC and your development environment (e.g., Visual Studio) are up to date. Updates may include important fixes and improvements.
    • Review any documentation or readme files that came with the robot skill. They may provide specific instructions on setting up and running the skill.
  7. Community and Support:
    • If the issue persists, consider reaching out to the Synthiam community or support for assistance. They may have additional insights or solutions for your specific situation.
By following these steps, you should be able to resolve the missing EZ_Builder library error and successfully run the robot skill. If you have any further questions or need additional help, feel free to ask!
