Hello Athena,
Is it possible to send a query through Bing Search and then receive the results in my Python script? I'm looking to integrate these search results into my project using Synthiam ARC. Could you provide some guidance on how to achieve this integration?
Thank you!
In Synthiam ARC, you can use various commands to control your robot's actions, such as speaking, moving, or performing specific animations. The
SayEZB()command is used for text-to-speech through the EZ-B's audio system. For other actions like moving or performing animations, you can use different commands. Here's a brief overview of some common commands you might use:Movement Commands
Servo and Animation Commands
Audio Commands
Custom Animations and Actions
For custom actions like "laugh" or "eye roll," you would typically create these as animations using the Auto Position skill or similar. Here's how you might set up a custom action:
AutoPositionAction()command with the name of your custom action.Example of Custom Action Command
Using TCP Commands
If you're using TCP commands to control your robot, you would send these commands over a network connection to ARC. The exact syntax and method depend on how your TCP server is set up to interpret and execute these commands.
Additional Resources
For more detailed information on creating custom animations and using commands, you can refer to the Synthiam ARC documentation and explore the Auto Position skill for creating animations.
If you have specific actions in mind and need help setting them up, feel free to ask for more detailed guidance!
@Athena "If you're using TCP commands to control your robot, you would send these commands over a network connection to ARC. The exact syntax and method depend on how your TCP server is set up to interpret and execute these commands" Give some example of syntax
When using TCP commands to control your robot with Synthiam ARC,you'll typically set up a TCP server within ARC to listen for incoming commands. The syntax for these commands will depend on how you've configured your server to interpret them. Here's a general guide on how you might structure these commands and some examples:
Setting Up a TCP Server in ARC
Example TCP Command Syntax
The syntax for TCP commands will depend on how you parse them in your ARC project. Here are some examples of how you might structure commands:
Text-to-Speech Command:
SayEZB(Hello world)Movement Command:
MoveForward()Servo Position Command:
SetServo(D0, 90)Custom Animation Command:
AutoPositionAction(Laugh)Parsing Commands in ARC
To handle these commands in ARC, you would typically use a script to parse the incoming TCP data and execute the corresponding ARC commands. Here's a simple example of how you might parse a command:
Notes
By setting up a TCP server and using a script to parse commands, you can control your robot remotely using custom TCP commands. If you have specific commands or actions in mind, feel free to ask for more detailed guidance!
There is also a code snippet on the modules Python page in the support section for doing remote tcp connection. This example is explained that will use ezscript commands over the tcp, which you can send from a remote Python script. Here is the link: https://synthiam.com/Support/python-api/add-custom-python-modules
@Athena how to control speed of the servo during rotation
@Athena how increase sound with bigger speaker
To control the speed of a servo during rotation and to increase sound output with a bigger speaker, follow these guidelines:
Controlling servo Speed
Check servo Compatibility:
Set servo Speed in ARC:
Servo.setSpeed()function in ARC to control the speed of the servo. The speed value typically ranges from 0 (fastest) to 10 (slowest).Adjust Speed in Scripts:
Increasing Sound with a Bigger Speaker
Check EZ-B Audio Output:
Use an Amplifier:
Adjust Volume in ARC:
Audio.setVolume()function to adjust the volume level in ARC. The volume level ranges from 0 (quiet) to 200 (2x overdrive).Speaker Specifications:
Power Supply:
By following these steps, you can control the speed of your servo and increase the sound output using a bigger speaker. If you have any specific questions or need further assistance, feel free to ask!
@Athena message="Hello word" command='SayEZB()' correc t the code
