Servo Speed icon Servo Speed — Adjust servo/PWM speed (0-20) between two positions to quickly experiment and tune motion; select board/port; settings aren't saved. Try it →
How To Use Bing Speech Recognition With Python
Hello Athena,
Is it possible to send a query through Bing Search and then receive the results in my Python script? I'm looking to integrate these search results into my project using Synthiam ARC. Could you provide some guidance on how to achieve this integration?
Thank you!
EZ-B Iotiny by EZ-Robot
Servos 8
ADC 2
Digital 8
ChatGPT chatbot for robots with memory, image description, personality scripting, and voice conversation via OpenAI API
Sounds like the robot skill you downloaded is out of date. Significantly out of date because the namespaces have changed several years ago. What robot skill did you download and where did you get it from. That information would be relevant to answer a question.
@Athena Bing search taking time to retrieve responses from ChatGPT, please suggest how to increase respond time
Without knowing what GPT model you are using, we can suggest selecting a quicker model. The default model is gpt-4o, however the gpt-4o-mini is fastest. Use the gpt-4o-mini model for quickest response.
Are you using Bing Speech? I use that also and notice that at times the response rate is slow. Sometimes it's fast. I kind of thinking has something to do with speed of the internet at the time and how many people are using it? Historically around Christmas there's more people on internet perhaps that is knowing things down? @Athena I would also like to know if there any tricks to speeding send and response up in Bing speech and if slow response from Bing is due to internet congestion.
#13   — Edited
The response time for Bing Speech or any online service can indeed be influenced by several factors, including internet congestion, server load, and network conditions. Here are some insights and tips to potentially improve response times:
Factors Affecting Response Time
  1. Internet Congestion
    During peak times, such as holidays or major events, internet traffic can increase significantly, leading to slower response times.
  2. Server Load
    The server handling the requests might be experiencing high demand, which can slow down processing times.
  3. Network Conditions
    The quality and speed of your internet connection can impact how quickly requests are sent and responses are received.
Tips to Improve Response Time
  1. Optimize Network
    • Ensure you have a stable and fast internet connection.
    • Use a wired connection instead of Wi-Fi if possible, as it can provide more consistent speeds.
  2. Monitor and Analyze
    • Use monitoring tools to track the performance of your requests and identify any bottlenecks.
When third-party online services are used, such as Bing Speech Recognition, you're at the mercy of their processing capability-which is generally much faster than our computers. Because it uses the Internet, you'll want to ensure you have a fast and steady internet connection. But the amount of data being transmitted is so small that it really wouldn't matter that much unless your network is super slow for some reason.
That's a great point! When using third-party online services like Bing Speech Recognition, the processing is done on their servers, which are typically optimized for speed and efficiency. Here are a few additional considerations to keep in mind:
Considerations for Using Online Services
  1. Internet Speed:
    • While the data packets are small, a stable and fast internet connection ensures that requests and responses are transmitted quickly.
    • If you're experiencing slow response times, check your network speed and stability.
  2. Service Availability:
    • Sometimes, the service provider might be undergoing maintenance or experiencing high demand, which can affect response times.
    • Check the service status page if available, to see if there are any known issues.
  3. Local Caching:
    • If your application allows, consider caching frequent requests locally to reduce the number of calls to the service.
    • This can help improve response times for repeated queries.
  4. Error Handling:
    • Implement robust error handling to manage timeouts or failed requests gracefully.
    • Retry logic can be added to handle temporary network issues.
  5. Service Level Agreement (SLA):
    • Review the SLA provided by the service to understand the expected performance and any guarantees they offer.
  6. Alternative Services:
    • If response times are consistently slow, consider exploring alternative services that might offer better performance for your specific use case.
By ensuring a good internet connection and implementing best practices for using online services, you can optimize the performance of your application when integrating with services like Bing Speech Recognition. If you have any more questions or need further assistance, feel free to reach out!
#16
@Athena TCP command: command = "SayEZB("Hello word")\n" is to say hello, what are the other TCP commands for calling functions like laugh, turn right/left, eye roll etc
