Autonomous AI icon Autonomous AI — Autonomous AI robot skill with vision, speech, movement, animations, and self-directed task execution powered by LLMs. Try it →
How To Use Bing Speech Recognition With Python
Hello Athena,
Is it possible to send a query through Bing Search and then receive the results in my Python script? I'm looking to integrate these search results into my project using Synthiam ARC. Could you provide some guidance on how to achieve this integration?
Thank you!
EZ-B Iotiny by EZ-Robot
Servos 8
ADC 2
Digital 8
ChatGPT chatbot for robots with memory, image description, personality scripting, and voice conversation via OpenAI API
It looks like you're trying to use a command to make the EZ-B say "Hello world" using the SayEZB() function. Here's the corrected code in JavaScript for ARC:
var message = "Hello world";
Audio.sayEZB(message);
In this corrected code:
  • The message variable is defined with the string "Hello world".
  • The Audio.sayEZB() function is used to speak the text stored in the message variable through the EZ-B's audio system.
If you have any more questions or need further assistance, feel free to ask!
#26
@How to send a string stored in a variable as Tcp command to "SayEZB()" function
#27
@Athena How to send a string stored in a variable as Tcp command to "SayEZB()" function
To send a string stored in a variable as a TCP command to the SayEZB() function, you can use the Net.sendUDP() function to send the command over a network. Here's a step-by-step guide on how to achieve this:
  1. Store the String in a Variable: First, store the string you want to send in a variable.
  2. Format the Command: Format the command string to be sent over TCP. The command should be in the format that the receiving end expects. For example, if the receiving end expects a command like SayEZB("Hello world"), format it accordingly.
    var command = "SayEZB(" + message + ")";
  3. Send the Command via TCP: Use the Net.sendUDP() function to send the command to the desired IP address and port. Replace hostname and port with the appropriate values for your setup.
    var hostname = "192.168.1.100"; // Replace with the target IP address
    var port = 12345; // Replace with the target port number
    Net.sendUDP(hostname, port, command);
  4. Ensure the Receiving End is Listening: Make sure that the receiving end (e.g., another device or service) is set up to listen for incoming TCP commands on the specified port and can interpret the SayEZB() command.
By following these steps, you can send a string stored in a variable as a TCP command to the SayEZB() function. If you have any further questions or need additional assistance, feel free to ask!
#29   — Edited
 To better assist you, I recommend providing as much detail as possible about your goal. This will help the community (and Athena) understand your goals and offer targeted solutions.
Here are a few suggestions for improving your question:
1. Define Your Goal
  • What is your end objective? Are you trying to enable speech commands for a robot, transcribe audio files, or something else?
  • How do you envision Bing Speech Recognition fitting into your project?
2. Share Hardware and Software Details
  • What hardware are you working with (e.g., computer, microphone, robot controller like EZ-B)?
  • What software are you using (e.g., Python version, Synthiam ARC, any specific libraries or SDKs)?
  • Are you using Windows, macOS, or Linux?
3. Explain What You’ve Done So Far
  • Have you set up the Bing Speech API? If so, what steps did you follow?\n- Did you encounter any error messages? If yes, please share the exact error message or logs.
  • Have you tried any example code or tutorials? If so, which ones?
If you’re using a specific tutorial, library, or SDK, sharing links to those resources can help others understand your setup.
For more tips on asking effective questions, please refer to our guide: How to Ask Robot Building Questions.
Providing this information will make it easier for the community (and Athena) to help you achieve your goals. Let us know if you have any updates or additional details to share. We’re here to help!
#30
@Athena following codes are not working  command = "SayEZB(" + message + ")\n"
command="AutoPositionAction(Laugh)"
It looks like you're trying to construct commands for the SayEZB() and AutoPositionAction() functions in ARC using JavaScript or Python. Let's address each command separately and ensure they are correctly formatted.
SayEZB() Command
To send a string to the SayEZB() function, you need to ensure that the string is properly formatted and that the function is called correctly. Here's how you can do it:
// Store the message in a variable
// Construct the command for SayEZB
var command = "SayEZB('" + message + "')";
// Execute the command
AutoPositionAction() Command
For the AutoPositionAction() function, you need to ensure that the command is correctly formatted and that the Auto Position skill is properly referenced. Here's an example:
// Construct the command for AutoPositionAction
var action = "Laugh";
ControlCommand("Auto Position", "AutoPositionAction", action);
Key Points
  1. String Concatenation: Ensure that strings are concatenated correctly using + and that they are enclosed in quotes where necessary.
  2. Function Calls: Use the ControlCommand() function to interact with other robot skills, such as Auto Position.
  3. Skill Names: Make sure the skill names used in ControlCommand() match the names in your ARC project.
Troubleshooting
  • Check Skill Names: Ensure that the skill names in ControlCommand() match exactly with those in your ARC project.
  • Console Output: Use print() to output variables and check their values for debugging.
  • Error Messages: If there are any error messages, please share them for further assistance.
If you have any further questions or need additional help, feel free to ask!
#32   — Edited
It seems like you're trying to use a ControlCommand() to trigger an auto position. To get started, you can refer to this manual page for guidance on using control commands: ControlCommand Documentation.
To better assist you, could you explain your goal in more detail? What are you trying to achieve, and what have you tried so far? Providing additional information will help us understand your question and ensure you have the best experience.
Also, this guide on How to Ask Robot Building Questions might be helpful as you refine your query.
