How do I do this, do i insert actions somewhere or what.
Please help!
stress
Talk Servo V2
— Animate servos to simulate jaw/mouth with ARC text-to-speech; configurable vowel/consonant timing, start sync, multi-servo control, pause/stop.
Please help!
stress
To create a script, would click the project tab, then click the Add button. Click the scripting button on the window that comes up. From there, add a EZ-Script component or the EZ-Script Manager.
If you added the EZ-Script component, click the gear and give it a name then write your script. If you added a the EZ-Script Manager, click the add Script button and give it a name, the start your script.
Also, many controls give you the ability to add scripts to things, like the speech recognition component allows you to add a script to each of the speech commands that you add.
Can you explain what you are asking your robot to do?
A script means a billion things - please be specific and someone can help you
I would like my robot to be able to do things I make in the actions tab atomaticly. I just don't understand how to create one. Sorry if I am not descriptive anough I am new to this. The only robot I ever have had was a lego robot.
Thanks anyway!
Like DJ has said, it's a little difficult to help you as you need to be a little more specific in what your looking to do, and what robot you have. Try posting three simple examples of what you would like your robot to do automaticly, and maybe some can help by starting you off.
Also, have a look at the link below which is a tutorial for creating scripts. It will help you understand the basics. Don't worry about asking questions, just give as much detail as you can with what your asking. Details are your friend.
synthiam.com/Tutorials/Lesson/23
As you mentioned "actions", another useful tutorial is for the auto positioner linked below, and it has a great video demonstration too.
synthiam.com/Tutorials/Help.aspx?id=180
Thank you!
You can call an AutoPosition action in the script by entering this
ControlCommand("Auto Position", AutoPositionAction, "testAction")
The testAction text would be replaced with the name of the action you are trying to perform.
So if you want a condition to be met, to then call this action, your script would be something like this.
The first line is just a label that tells the goto at the end where to go back to The second like looks for the value returned by ADC port 0 to be greater than 50. The third line will cause the action called "testAction" to run if the value in the previous line greater that 50. The fourth line goes back to the label DoActionWhenADCConditionMet
There are a huge number of things you can do in scripts so knowing when you want to fire the action will help us to provide an answer that is more relevant to your exact situation.
As d.cochran has mentioned above, control commands are extremely useful for using actions in scripts. Essentially control commands are short cuts for making an action work, and pretty much every control, whether it's from a script you have made, scripts or controls from an example project, or a control you have added to your project yourself. This makes putting a robots actions together very easy as it doesn't require writing out new code.
i think he needs some pics an excample like dj made the video for me. treemonkey do you have skype.
