Inverse Kinematic Arm icon Inverse Kinematic Arm — Control robot arms with inverse and forward kinematics, converting X/Y/Z positions into joint motion and reporting end-effector location. Try it →
ah thanks alan.didn find this one.
@thetechguru, Is there a list or index of all the tutorials?
Thanks, Frank
I am not sure why people have so much trouble using and finding info in the Learn section here... I usually find what I want or need to know within a minute or two... The learn section and tutorial section are an easy to use, easy to find wealth of information... My dad used to say... "you just need to look past your nose".... Just my 2 cents... "Search" is your friend and the links Alan gave are also accessible right up there in the website's main page tool bar....
rr
i checked all tutorials and i didn see the one alan has. maybe i chould check longer.
i just check it again.dont see the one from alan.i made a pic ,usefull for everyone.
Nomad, it is in the ROLI course - 4th chapter. It is also in the assembly instructions in the ROLI sample project.
It could not have been in a more obvious location when looking for anything to do with ROLI.
There is also an entire Robot Program devoted to assembling and using ROLI that has more video if you need that: https://www.therobotprogram.com/Lesson/54?courseId=3
