Frequency Detector icon Frequency Detector — Detect audio frequencies via PC microphone (FFT), output a variable and drive servos within configurable min/max ranges with waveform feedback. Try it →
faengelm
thanks for the tip.
sorry to bring this up again.stil have problems with the H-bridge . mine left go's right and visa versa.only forwart and backwart is good. is this pic correct ?
#19
Hello @Nomad,
Yes, both pictures are correct.
hi jeremie
i connected it same as in pic.same colors.
so is this pic correct?
thank you
#21
Yes, those are the correct ports for Roli.
Use this picture as reference to see if the motors are connected to the correct side of the H-Bridge:
Left motor goes to the left side of the H-Bridge and right motor goes to the right side of the H-bridge.
yes thats the pic am looking for.but problem still same.am using a meccanoid, robot .i put the wheels on the outside of the robot. it gifs more stability.i think thats change the direction of left and right.
#23
Ah yes, that's the reason!
If you flip the orientation of the motor the robot will move in the opposite direction.
okay thanks jeremie.
