Feetech RS485 Servo icon Feetech RS485 Servo — Control Feetech serial bus smart servos via EZB UART or PC COM port in ARC using virtual ports mapped to servo IDs. Try it →
Help!  I Can't Get Y Camera To Work
I have the EZ camera and hooked it up just as described. My computer uploaded the drivers when I plugged in the dongle and it shows up in the dropdown list. When I select it, nothing. I get the red grid but no images. I have a digital set control set to the DO of the camera and turn it on. Still nothing.
What do I do?
#17
Camera is working but I guess I mounted it upside down. Any ideas out there how to loosen or remove all the hot glue without damaging the camera so I can rotate the camera 180 degrees?
#19
I didn't see a box to invert the image - yes, it is the image that is upside down.
#20
a stupid question, did you mod the camera? if so, do you know where is the top of the circut after taking it apart?
Yeah, I mounted it in the head upside down - it fit better that way. I never even thought of of the image being upside down, I kinda figured you could invert the image. But no such luck. I guess I will have to remove it and remount it. What a pain...lol
#22
THE CAMERA WORKS NOW!!!! :D
Thank you
#23
@robot56 - you're welcome, but the real thanks goes out to winstn60 as he was the first one brave enough to try this.
