EZ-B V3 Configuration icon EZ-B V3 Configuration — Manage EZ-B hardware settings: edit Bluetooth name and apply updates to restore altered configurations. Try it →
Did you check the fuse? Maybe you just need to change it out with a good one if it's blown.
What were you doing when it happened? Maybe it could be repaired if something is actually burnt.
Go through the troubleshooting. If its just a regulator those are a cheap fix. If you popped your microcontroller chip that can be purchased separately. I proactively bought 2 extra chips and Bluetooth modules so if I ever let the smoke out I have a quick replacement to swap with.;)
United Arab Emr
@jstarne1 : What did you mean by popping out the MCU Chip and replace it?
You do not need to add the Firmware into it? is it possible thru the EZB Firmware upgrade tool?
or is it available as separate pre-programed item on EZ-Robot Website?
Use the Contact Us form if you need a replacement chip , they can sell them separate preprogrammed with the firmware.
United Arab Emr
yep, make sense... no need to buy again the complete board ....thx:)
I had it wire to my H-bridge running script test, while it was plug into the certified bench power supply. Is there a troubleshooting guide to follow?
it was the Fuse. I measure the voltage across and it was showing 12v as it should, didn't bother taking it out. In my experience, blown fuse usually shown 0 V. I replaced it it work just fine.
Lol was looking for an excuse for my girlfriend to buy me a second EZ-B and she order it last night for me:) .
