Speech Script icon Speech Script — Run custom scripts when speech starts/ends to sync servos and LEDs to spoken $SpeechTxt, with loop support, stop button and logs. Try it →
Ezb Firmware Update Failure   Help
ok all was working fine with ARC until i decided to upgrade to 12 26 version. down loaded ok then tried to run firmware update program. failure program reported io exception and no com ports are visable in pull down. ARC has no problem displaying corect com port just firmware utility. bluetooth device com port is correct. help as i am locked out now since my pc is one version newer then control pcb.
#25
mitchmen14,
Hey, Buddy!  I came over from  the Arduino Platform too. It is an Easy system to work with.
At times, things can be frustrating for us all , but we have to Hang in there. If you don't give up hope and keep a positive attitude , things will get better. Remember, this field is in the pioneer stage and we are ALL Pioneers. Robots haven't moved as quickly as we had hoped. But, people like D.J. is making it much easier compared to what it used to be. I have been building robots since 1975 and the field is getting better very slowly.
We all value our time and when we have to waste it, it hurts. But, don't give up and it will be all worth it in the long run. Just be patient. The other day, I felt like D.J. was singling me out and not answering my question. But, I found out that he DOES care. His whole crew is at the Maker Fair expanding their customer base and learning new things to share with us. Usually, he has Very fast service.
Best of Luck!
MovieMaker
#26
now i have firmware version 25,5 confused
