Set Digital icon Set Digital — Toggle a digital I/O port between TTL low (0V) and high (3.3V/5V) in ARC; select board and port, simple on/off control-signal only. Try it →
Ezb Firmware Update Failure   Help
ok all was working fine with ARC until i decided to upgrade to 12 26 version. down loaded ok then tried to run firmware update program. failure program reported io exception and no com ports are visable in pull down. ARC has no problem displaying corect com port just firmware utility. bluetooth device com port is correct. help as i am locked out now since my pc is one version newer then control pcb.
#17
@mitchmen14 i wonder if there is an issue with encoding from your language. can you post your EZB file here?
#18
@mitchmen14 I just looked at your cloud db files. The files were saved with an old version of ARC, just like the message states. You will have to upgrade to the latest version. Delete your old cloud files and you'll be fine going forward.
Now that EZ-Cloud is stable, you will no longer run into this problem again.
if you look at the sharp sensor when powered by the EZ-B with a camera phone not an Iphone 4S you should see a bright blue light it will show if the transmit part of the sensor is working. It is visible on a 4S but faint much brighter on a Iphone 4 interestingly
The sensor seems to work
samsung galaxy s2 camera
#21
cloud still does not load I'm going to reinstall Ez_Builder thanks for the help I'll try around a bit
servo.EZB
#22
@mitchmen14 Using a camera is not a way to check the sensor. It will only check 1/2 of the sensor. The sensor has two parts, a emitter and receive. The emitter you can check with a camera, but that is only 1/2 of it's functionality. The only way to check the receiver is by connecting it to an EZ-B. If it does not display data, then the receiver does not work.
You can check the ADC port of the EZ-B by following my earlier suggestions.
As for the EZ-Cloud. Again, you will have to delete your existing files that are on the cloud. They are from the older version.
#23
So no idea but I give up the whole story cost me too much time
the only thing I still like to try is downgrade to the old firmware and builder can you send me pls the old version v12 by email? if it is possible sry for the many problems
blush
EZ Firmware 15.8 not Working!!!
  1. i reinstall bluetooth and ARC
  2. check for windows update
  3. I have tested it on three different pc
  4. I've given it to a friend in the hope that he has more luck
same problem............
I would love to build something with the ezboard I now have at least one year and could do anything with it
the thing just makes problems! I have four Arduino and work great
